September 22, 2026, 12:50:41 pm
| | |-+  Gearbox Ratios
Author Topic: Gearbox Ratios  (Read 4702 times)
71CALRIPPER
« on: May 26, 2010, 10:53:58 am »
Looking for peoples thoughts on these gear ratios for a NA motor but not a high reving motor.
More street than strip
gears (weddle)
3.78
2.36
1.31 (welded)
1.04 (welded)
3.88 ring and pinion
Thank you
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #1 on: May 26, 2010, 13:37:23 pm »
  I think this will have you more in the high reving range personaly.  For street I'd suggest the 2.06 second.  and a .89 fourth.
« Reply #2 on: May 26, 2010, 14:24:29 pm »
what jason said, but with a 4.12 RP. strongest 'stockish' gearbox and a good cruiser/driver box IMHO.
« Reply #3 on: May 26, 2010, 16:59:19 pm »
That sounds like a terrible gearset. Long 1st, close second, huge 2-3 drop, and a final drive that works out a little shorter than a stock 4.12 box. I'd take a stock ratio 4.12 box over that any day.
« Reply #4 on: May 27, 2010, 06:07:07 am »
For that tight second, your 3rd is too tall.  Build it that way, you'll experience a bog everytime you hit 3rd.
A better split between that 2nd and that 4th is a 1.50.
I agree with the above.  4.12 is where it's at.
Jason Foster
« Reply #5 on: May 29, 2010, 05:51:39 am »
  Well he said he was running the 3.88,  for 4.12 I suggest
       3.78
       2.06
       1.26
         .82                 Keeping in mind he's looking for streetable cruising.
FDK/mrpedrini
« Reply #6 on: May 29, 2010, 16:35:56 pm »
What kind of engine and horsepower do you have? I think we might searching for the same solution.... (check out my topic: 2017cc gearbox selection).
kind regards, Dennis
