October 13, 2026, 03:35:33 am
More power, Scotty!
Topic: More power, Scotty! (Read 12111 times)
deano
More power, Scotty!
June 03, 2010, 00:01:23 am »
Found this one on the web.....
Anglia Obsolete Guru
'67 Heaven
Re: More power, Scotty!
June 03, 2010, 09:08:46 am »
I like to see the sheet metal that goes on that!
June 03, 2010, 11:21:55 am »
awesome! someone should build a flat 6 out of it topped off with some proper 40IDA 3C Webers!
DVK ~
bodgit
June 03, 2010, 14:13:12 pm »
Quote from: HotRod Ted on June 03, 2010, 09:08:46 am
That'd be one helluva fan shroud.
Matt
June 03, 2010, 14:13:39 pm »
Hello, RIMCO? Yeah, I have a couple cases I need a linebore on...
June 03, 2010, 15:01:50 pm »
"Hello, is that Scat? Listen, when I said I wanted a LONG stroker crankshaft, I didn't mean a long-stroke crankshaft, I meant a LONG crankshaft with a..." (Click) "Er, hello? Hello? Anybody there?"
June 03, 2010, 18:54:20 pm »
This is South America, isnīt it?
Bad bug
June 03, 2010, 23:50:22 pm »
Yes these where made in Brazil.
June 04, 2010, 00:11:06 am »
DANG, Deano... those are COOL! Nice find.
June 04, 2010, 00:46:26 am »
Ya but how do you close the decklid?
Speed-Randy
June 04, 2010, 00:58:20 am »
you gotta use the stand-offs Rick, DUH!!!!
www.vdubspeedshack.com
June 04, 2010, 02:14:22 am »
Just wondering if those are new or old? Could they be from the Fittipaldi car? I don't know when that was but it was quite a while ago...
kingsburgphil
June 04, 2010, 03:22:45 am »
I think the Fittipaldi car used a pair of 1500's, mated front to rear. How I don't know, but I suspect with a toothed sprocket on the end of each crank, wrapped with a double row chain to allow deflection between the cranks. Just a guess
June 04, 2010, 04:56:34 am »
I wonder how the oil galleries were mated ?
Will it require a cooler for each boss ?
Jeff68
June 04, 2010, 13:57:22 pm »
I wish we could see the crankshaft in these beasties.......I'll take the flat eight!
June 04, 2010, 16:37:47 pm »
Here ya go!
http://www.youtube.com/v/tXKcpbFF7WI
http://www.youtube.com/v/Zto2UDCUyoY
All you need to know here:
http://mestrejoca.blogspot.com/2009/03/as-entranhas-do-motor-jamaro.html
Google translation:
Exclusively for the Blog Master Joca the exclusive photos and unreleased bowel of twin 8-cylinder boxer and his new lubrication system.
After more than 30 motor driven and accelerated in 2007, it was found that the characteristics of the VW engine, the oil returns by gravity to the crankcase and valve tappets.
Just when work is linked with poor lubrication, because the ducts are longer and more demanding. This caused the wear of the bearings prior to connecting rods. We kept two of the kits 1500 new Mahle totaling 3000 cc.
Carefully studying the situation, the mechanic Mark and I, we conclude by adding an additional electric pump, used in exchange competition, which worked very well on the bench with 6 kg of pressure.
We shut the engine with Militec areas of friction now in the afternoon and is being installed in the Beetle for next week, in principle, subject to record the program on Rede Globo Autoesporte.
We conclude that this was the turning point of the engine at that time (1969) and our strategy is as follows:
1 - Before starting the engine will turn on the electric pump for lubrication prior (installed on the same level of housing to remain full).
2 - The drive motor will start operating a mechanical pump and then, following the two clocks, oil pressure, the two decide to keep running continuously or not.
3 - Let's make a break and in the future, if the engine match, order a forged crankshaft torsional and less.
4 - This week following pictures the "bicho" accelerating. Ronco bem encorpado! Snoring and stocky!
Joachim, can we call this engine JAMAR to honor those geniuses who manufactured this jewel?
You, as one of the first and only known the trajectory of this set, has the moral power to this definition.
Last Edit: June 04, 2010, 16:45:15 pm by Fastbrit
June 04, 2010, 17:12:23 pm »
Seems to me the exhaust port layout would favor starting with a type 4 engine.
Fasterbrit
June 04, 2010, 17:42:16 pm »
Ronco bem encorpado! Snoring and stocky! Don't you just love Babelfish?
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
June 04, 2010, 20:10:38 pm »
....and while we're welding things together to be like the Porsche guys, some of them are shortening things a bit to be...uh... more like
us
(this is a customer of mine that does these)
June 05, 2010, 02:38:45 am »
Those 911-4's are sweet. Does it start life as the big 3.6?
glenn
June 05, 2010, 04:17:09 am »
Quote from: Zach Gomulka on June 05, 2010, 02:38:45 am
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
