September 23, 2026, 13:36:56 pm
Wanted
IRS Bug Gearbox broken - T1 Chassis - Beetle rear 1/4 panel complete
Topic: IRS Bug Gearbox broken - T1 Chassis - Beetle rear 1/4 panel complete (Read 2847 times)
Prowagen
June 06, 2010, 14:32:45 pm »
Hi guys, need a few bits and pieces:
IRS Beetle gearbox; Can be completely broken as long as the case is fine and it has CV output shafts as its just being used for a mock up.
Chassis; Ideally T1 King and link pin or ball joint with swing axle setup, but others considered such as Ghia, TYPE 3, IRS etc.
Needs to be in good shape and require real minor work or just painting!
Rear Bug 1/4 panel; Needs to be complete rear 1/4 with window appeture and inner wing etc. Needs to be un damaged and clean enough to just prep and paint.
Any distance considered if the goods are right.
Cheers,
Rob.
