September 22, 2026, 16:29:54 pm
nickasil 94's
Topic: nickasil 94's (Read 7048 times)
kingsburgphil
nickasil 94's
June 07, 2010, 03:57:47 am »
I'm probably the last person to stumble across these.....Anyone have any experience with them?
Personally I have a lot of questions. Will they hold up under high cyl. pressures?
What are the overall dimensions of the cyls.? And what about pistons? When Mahle makes/made
Nickies the pistons were engineered to work in those cyls. as a matched set with optimized clearances.
Or so I have been led to believe, please correct me if I'm wrong
http://www.hummelengines.com/
And yes, I did use the search function first
Last Edit: June 07, 2010, 06:33:31 am by kingsburgphil
Re: nickasil 94's
June 07, 2010, 04:08:45 am »
I've never heard of Hummel Engines? Aircraft use, I presume? LN Engineering was making these a few years ago, but I've heard that the cost to produce overwhelmed demand and therefore production stopped...
Re: nickasil 94's
June 07, 2010, 04:59:07 am »
$1300 for 4.
IIRC, LN Engineering's price was above $2k.
Re: nickasil 94's
June 07, 2010, 05:21:21 am »
Quote from: Bruce on June 07, 2010, 04:59:07 am
$1300 for 4.
Yes, but as I remember with LN Engineering you got cylinders, pistons, and head studs. That's $1300 for only the cylinders.
Arnoud
Re: nickasil 94's
June 07, 2010, 05:42:06 am »
>2K for the cilinders only,add to that 350$ for the studs and approx.500$ for the pistons
kingsburgphil
Re: nickasil 94's
June 07, 2010, 06:11:34 am »
Not that I'm in love with what I see, But what did a set of Okrasa/Mahle 90's cost in 1980, allowing for inflation?
I'd like nothing more than sliding a set of these over my JE 94's, after all what's not to like? Superior cooling, meaning more
squeeze, long life and less weight. Crack open a 70's/80's 911 and what do you see? (911T excepted). Will they work for our
application and are they worth the money? Good question.....
What if they were made at the Peoples Factory #7 in Chongqing to our spec's? How much would you pay? Just a thought
Last Edit: June 07, 2010, 07:39:27 am by kingsburgphil
Arnoud
Re: nickasil 94's
June 07, 2010, 15:05:05 pm »
Oettinger/Mahle P+C's often pop up on German boards-app.300-500Eur/set(pistons are heavy).
QSC makes NiCaSil cilinders-I've got a set for my type4(with J+E's-through EMW).Make sure they are measured for roundness and before usage.
Running-clearence and ringpacks are different to the ones used with cast iron barrels.
Regards,Arnoud
kingsburgphil
Re: nickasil 94's
June 08, 2010, 00:55:43 am »
Since we're all talking price, here's LN's pricing for 2010. The Hummel cyl's. appear to be different,
better or worse ??
http://www.lnengineering.com/type1.html
Great website! Learned a lot, especially about lubricants. I hope there isn't a quiz afterward.
Last Edit: June 08, 2010, 05:31:33 am by kingsburgphil
Re: nickasil 94's
June 08, 2010, 01:51:14 am »
I could see plopping down $800,
maybe
$1000 for a
TRICK
set of slugs and jugs, but I can't justify those prices.
volkskris
Re: nickasil 94's
June 09, 2010, 21:12:31 pm »
LN didn't just design that jugs and built them, but they have done a lot of r&d on those jugs. if they want get their cost's back, they have to ask those prices.
but your getting the best cilinder for a type 1 available.
Re: nickasil 94's
June 09, 2010, 22:24:47 pm »
Quote from: volkskris on June 09, 2010, 21:12:31 pm
I understand that
Re: nickasil 94's
June 09, 2010, 22:34:00 pm »
try buying Mahle nikasils for a 3.3 930T, dealer list is currently $5390.82
just for perspective.
Re: nickasil 94's
June 09, 2010, 22:53:23 pm »
Quote from: Alligator on June 09, 2010, 22:34:00 pm
That's why I don't own a Porsche
