October 14, 2026, 02:41:23 am
| | |-+  40 DRLA Dellorto help needed
Author Topic: 40 DRLA Dellorto help needed  (Read 6753 times)
« on: June 09, 2010, 17:25:05 pm »
My 63 Bug is running a bit rough, after further investigation when you look down one of the carbs no fuel is coimng out of one side of that carb (the other is fine) The fuel squirter (if thats what it is!) seems blocked.
How do I cure this problem?
Is it a carb off job?
Lee
Martin Greaves
10.88@128.58
« Reply #1 on: June 09, 2010, 17:26:40 pm »
Put some IDA's on it. Tongue Cheesy Grin
« Reply #2 on: June 09, 2010, 17:39:14 pm »
When you start practising what you preach I may listen Wink
Martin Greaves
10.88@128.58
« Reply #3 on: June 09, 2010, 18:24:17 pm »
Well i was going to say put a turbo on it but i dont want your other half going quicker than you. Cheesy
« Reply #4 on: June 09, 2010, 19:57:55 pm »
I was thinking that today, its ripe for turbo!
Theres no way Nicola will ever go quicker than me Grin
Phil West
« Reply #5 on: June 09, 2010, 19:59:50 pm »
Lee
Hi Lee,
The accelerator pump jet is easily removable on it's own from the side - you don't need to remove the carb top like you do on an IDA.  As a start I would suggest removing both from that side and giving them a good look and a blow through and clean.  As long as you are sure that  is the issue.  If not then do the same for the idle jets and the carb fuel filter for that side.
Phil
streetvw
« Reply #6 on: June 09, 2010, 20:04:46 pm »
hope you looking after that old motor
it's not doing to bad considering it was built 16 years ago Shocked
« Reply #7 on: June 09, 2010, 20:20:48 pm »
Hi,
Sure is doing ok, to be fair you probably did more miles on it than I have though Shocked
Need to start using it again....
Lee
