August 12, 2026, 08:08:57 am
| | |-+  AFR for E85 and Turbo at WOT!!
Author Topic: AFR for E85 and Turbo at WOT!!  (Read 10577 times)
Tom G.
« on: June 09, 2010, 22:33:46 pm »
Hello,
I want to know of the guys who are running fuel injection and turbo which are the common AFR values for Aircooled engines which use E85 (ethanol)?
My Wideband ZEITRONIX only handle 9,0-22 AFR. I have read the best AFR for high performance and E85 is about 6.8 AFR.
But perhaps some users has better results in leaner conditions?
I am happy to hear some opinions :-)
Regards
Tom
Airspeed
« Reply #1 on: June 09, 2010, 23:15:00 pm »
Use Lambda! AFR gets confusing real quick.
The Innovate LM1 and LM2 can be set for ethanol to boot.
« Reply #2 on: June 09, 2010, 23:46:22 pm »
A 9.0 AFR will give you a 15% rich for E85. I would try to keep it right at 9.0 -- rich is good
Normally 14.7 is perfect for gas and most guys try to keep their turbo cars running rich at 11.5-12.5
Martin
Cash Converter....
« Reply #3 on: June 10, 2010, 07:54:08 am »
What he said! use Lambda is the same what ever fuel you use. we shoot for 0.79 - 0.8
Martin
Martin
www.taylormachine.co.uk
OFF/500
Tom G.
« Reply #4 on: June 10, 2010, 08:38:29 am »
Yes this is true it makes me confusing...
But you and the other said, that i should use lambda...If i use lambda for example 0,75 for WOT, than it is only the oxygen residal content for normal gasoline or?
If i wants to calibrated or messure for E85 the lambda value has to be lower?! I can not convert values in my widebandsystem for Ethanol...:-((
Regards
Tom
« Reply #5 on: June 10, 2010, 09:18:46 am »
 Smiley
I`m in the same boat as you Tom. A old habit it hard to get rid off and since I have always used AF I prefer to still use AF on my new engine running on E85
I use a Innovative LM 1 which is set to gasoline and maybe later I will get my head around the lambda values. I aim for 11.2 to 12.2 on my engine. Try finding a dyno where they use Lambda on their equipment.
Good luck.
Best rgs
BB
« Last Edit: June 10, 2010, 10:06:19 am by BeetleBug » Logged
Martin
Cash Converter....
« Reply #6 on: June 10, 2010, 10:32:16 am »
Regards
Tom
Tom, if you use Lambda, its the same for all fuel's, you dont have to convert anything. you can swith your LM1 to read just Lambda.
Regards
Martin
Martin
OFF/500
james wotton
« Reply #7 on: June 10, 2010, 19:48:30 pm »
my car was mapped at .8 lamda no problem for a whole season  Cool
9.91 @ 139.90
outlawflatfour 2010 and 2011 champion.
