September 22, 2026, 07:09:20 am
| | |-+  Fuel Pumps & Regulators
Author Topic: Fuel Pumps & Regulators  (Read 3531 times)
BeetleJuice
« on: June 11, 2010, 06:14:26 am »
I have a 2332 with IDA's and have misplaced my Fuel Pump! Huh I suppose that what you get when everything has been sitting around for 10yrs. It was a SU unit which I believe was never enough to feed my previous engine anyway.
What is a good quality pump/regulator combo nowadays? I am running 3/8 inch fuel line too.
Not really keen on Holley, would like something Euro myself, but I am open to all options. Is it a better option to have a pump with a built in regulator like my previous pump?
I see CB advertise a rotary pump, but an engineering friend of mine doesn't like them.
Any thoughts appreciated.
Craig
BeetleJuice
« Reply #1 on: June 11, 2010, 12:21:11 pm »
HUCO pumps? Anybody used these? Part no 133000
karl h
« Reply #2 on: June 11, 2010, 13:50:09 pm »
i have used HÜCO in the past, both with Dellortos and Kadrons
dont know if it is the same part as you want to use, but mine had plastic multiposable in/outlets on top. get spares of theses, they tend to break when hoses are pulled of
BeetleJuice
« Reply #3 on: June 22, 2010, 06:25:53 am »
Thanks for the info Karl. That has turned me right off about the plastic ends!
Looks like I may go with a Mallory 4070LP. 72GPH free flow and 30GPH @ 4psi. Has an internal bypass set at 4psi. I like that in case of a regulator malfunction!
