October 14, 2026, 11:56:50 am
| | |-+  Wish to run MSD wires on stock distributor?
Author Topic: Wish to run MSD wires on stock distributor?  (Read 5902 times)
airstuff
« on: June 14, 2010, 13:11:44 pm »
We have found this Ford distributor Cap,which fits perfecly Bosch standard SVDA,009,010,011 and other stock style distributors(Alfa Rome 33 Bisch system which fits on Bug with a shaft distancer).It and allows the use of excellent MSD ignition cables/wires or you can even use cheaper CB Magnaspark cables.
What are your thoughts,would you run MSD wires on stock style distributor?I have them fitted to my bug,and it works flawlessly,even with points.Sparks are more accurate.
Some of my friends have found this stock style silicon wires crappy.
Originally it is intended for use on Ford Granada 1.8,2.0 & Sierra 1.8,2.0
Cap Bosch Part number:  1 235 522 374
Ford Part number: 6 146 423
Facet(replacement) number: 2.7530/5PHT
You can find Bosch original or Facet reproduction distributor caps.
« Last Edit: June 14, 2010, 13:16:58 pm by airstuff » Logged
« Reply #1 on: June 16, 2010, 03:44:38 am »
MSD makes wires that fit on the stock (009) cap, I used them years ago on my '67. I think I had to rob the seals off of another set of plugs, though.
JS
« Reply #2 on: June 16, 2010, 06:08:58 am »
I'm curious(and getting new wires). How does these wires provide more accurate spark?
Signature.
margaret
« Reply #3 on: March 19, 2011, 04:02:50 am »
hi guys! I have a 1997 vw with an H22A4 engine and somebody pulled my plug wires off my distributor cap and I have no idea what order they go back on in. Please help me.
Kaferdog
« Reply #4 on: March 19, 2011, 07:18:02 am »
Margret..try here ...
http://www.chircoestore.com/catalog/smf/index.php?topic=3432.0
