September 24, 2026, 15:10:43 pm
| |-+  For sale!
| | |-+  Lowering Kits for Type 2 bus
Author Topic: Lowering Kits for Type 2 bus  (Read 4044 times)
Devils speedshop
« on: June 15, 2010, 08:38:35 am »
Hey Im selling out T2 lowering kit for a very good price.
NOW 87 Euro for a kpl. set normal price 117 euro
http://teamangoraracing.dk/viewtopic.php?f=7&t=49
Christian
Team Angora Racing
Phone: +45 21291280
AngoraRacing@gmail.com
Christian Ulberg
Denmark
kev d
« Reply #1 on: June 20, 2010, 23:39:54 pm »
Hi Christian,
Dumb sounding question but how do these work?
Do you need to go into the lower tube behind the pitman arm bracket?
I've only lowered a couple of t2's & done it by cutting & turning the tube centers, looking for an easier way on my new bus!
Cheers,
Kev
Devils speedshop
« Reply #2 on: June 21, 2010, 08:40:12 am »
Yes you have to drill teh 3 points out that hold the center part so it can turn, then you weld the teeth on to the beam and you can ajust the hight.
Christian
Team Angora Racing
Phone: +45 21291280
Christian Ulberg
Denmark
kev d
« Reply #3 on: June 21, 2010, 09:04:28 am »
So do you only fit an ajuster into the top tube?
How much drop does it give?
Cheers,
Kev
Devils speedshop
« Reply #4 on: June 21, 2010, 09:36:34 am »
You just put the bolt that comes with the kit into the org. hole on the center part and then you turn the center part.
Its you ball joint that says stop, so like 220-250 mm
Christian
Team Angora Racing
Phone: +45 21291280
Christian Ulberg
Denmark
paul_f
« Reply #5 on: June 21, 2010, 11:55:23 am »
I'd put an adjuster in each tube otherwise the springs are acting against each other and you can get some strange effects.
I drill out the 3 dimples in the top tube and just the one in the lower tube (that is accessible without removing the steering pin housing).
Then use an old jack handle slid into the beam to hammer the centre of the lower tube along - this pushes out the dimples that you can't get to.
