September 24, 2026, 21:53:11 pm
| |-+  For sale!
| | |-+  Performance Parts - Line-Lock,Turbo,Engine MSD Parts, MORE added 14th Jan
Pages: [1] 2 Print
Author Topic: Performance Parts - Line-Lock,Turbo,Engine MSD Parts, MORE added 14th Jan  (Read 35473 times)
Jo Clifford
« on: June 23, 2010, 18:12:01 pm »
Hurst Roll Control / Line-Lock - Brand New in Box £ each - see pic below    All sold, will have more next month
Turbonetics 60/2  T04  - used for 8 months only on Richie's Cab, went 9.67 with this turbo.  Still in perfect working order.
£650 - see pic below
Scat Chromoly Crankshafts 3 available all new in box.
78.8 stroke, 82 stroke both with VW rod journals  £325 each both sold
also 84 stroke Chevy Rod journals  £345 - SOLD/Josef
Wiseco 94mm Pistons, notched, new in box with rings and pins    £330 per set    (2 sets available) 1 set sold
Mahle 94mm Pistons and cylinders, new in box, for stroker crank  £230 per set
Scat 1 1/2 quart sump, new in box   £55  (2 available)
Scat H-Beam Rods  5.4 VW Journal and 5.5 Chevy Journal  - all new   -   £239 per set
Kennedy Stage 1 & Stage 2 clutch covers, New    £95 each
Total Seal 2nd rings  94mm  New    £55   (2 sets available)
Straight cut cam gears New     £80(2 sets available)
Scat 8mm Chromoly head studs, New    £45
Scat 10mm Chromoly Head studs, New   £45
I will add more as we sort it out from the boxes
26mm & 30mm shadeck oil pumps £26[add £5 for full flow]
« Last Edit: June 12, 2012, 13:46:05 pm by Jo Clifford » Logged
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Jo Clifford
« Reply #1 on: June 23, 2010, 21:20:03 pm »
Scat 36mm Chromoly Gland Nut   New     £28
Jaycee IDA -6 Fuel inlet kit    New           £30  (1 sold)  -  2 more available
Scat 1.4:1 Pro ratio rockers        New      £215
Engle FK87 & FK89  Clearanced for stroker crank, new in box          £80 each
Mallory Fuel Pressure Regulator, new in box   £90
« Last Edit: July 09, 2010, 23:02:04 pm by Jo Clifford » Logged
Josef
« Reply #2 on: June 23, 2010, 21:51:34 pm »
PM sent
/Josef
« Reply #3 on: June 23, 2010, 22:03:50 pm »
What part number is the regulator?
Jo Clifford
« Reply #4 on: June 25, 2010, 11:04:47 am »
Jo Clifford
« Reply #5 on: June 25, 2010, 11:21:19 am »
Jaycee IDA -6 Fuel inlet kit    New           £30  -  PENDING
Jo Clifford
« Reply #6 on: June 25, 2010, 12:18:03 pm »
Hurst Roll Control / Line-Lock - Brand New in Box 3 off
£112 each - see pic below
also 84 stroke Chevy Rod journals  £345  -  PENDING - Josef
Scat 1 1/2 quart sump, new in box   £55  (available)
Scat H-Beam Rods  5.4 VW Journal and 5.5 Chevy Journal available - all new   -   £239 per set
Straight cut cam gears New     £75    (2 sets available)
« Last Edit: June 12, 2012, 13:46:42 pm by Jo Clifford » Logged
« Reply #7 on: June 25, 2010, 16:21:25 pm »
Thanks, but i need a 3 port version Smiley
Jo Clifford
« Reply #8 on: June 26, 2010, 19:51:04 pm »
Can deliver to SCC - Free of charge    Smiley
Jo Clifford
« Reply #9 on: July 09, 2010, 13:31:59 pm »
Hurst Roll Control / Line-Lock - Brand New in Box £112 each - see pic below    3 available - 1 pending
still have 1 78.87 1 82mm Scat chromoly cranks left
2 Hurst roll controll/line locks available still
h beam rods VW journal and chevy journal 5.4 and 5.5 still available
Engle cams,FK 87,89,42,44,46,47 all available
1 set wiseco 94mm pistons with valve notches,with rings and pins.new£330
Straight cut cam gears  £80
And lots more,just ask if you need performance engine parts Smiley
Jo
« Last Edit: June 12, 2012, 13:48:07 pm by Jo Clifford » Logged
Jesse/DVK
'64 2176cc
« Reply #10 on: July 09, 2010, 14:07:27 pm »
Thanks!
71CALRIPPER
« Reply #11 on: July 09, 2010, 15:09:04 pm »
Any twin quiet packs left?
Jo Clifford
« Reply #12 on: July 09, 2010, 16:02:18 pm »
Yes, still have them in stock     Smiley
Eddie DVK
« Reply #13 on: July 10, 2010, 08:43:52 am »
Jo maybe you have some pictures of those.
Kind regards
Edgar
Regards Edgar
Jo Clifford
« Reply #14 on: July 10, 2010, 09:30:15 am »
Kind regards
Edgar
Here's a picture of one on my car.
If you need more let me know.
Jo
kev d
« Reply #15 on: July 10, 2010, 10:45:03 am »
Hi Jo,
Put me down for the line lock Grin
Cheers,
Kev
Jo Clifford
« Reply #16 on: July 10, 2010, 15:05:07 pm »
Hi Jo,
Cheers,
Kev
OK, do you need it posted or hand delivered    Grin
Jo
kev d
« Reply #17 on: July 10, 2010, 18:19:38 pm »
Hand works just fine for me Wink
Are you up here or down there anyway??
Jo Clifford
« Reply #18 on: July 13, 2010, 10:19:17 am »
In sunny Essex at the moment    Smiley
glennc
« Reply #19 on: September 25, 2010, 22:25:49 pm »
Did you sell the turbo ?
1 5/8 coated header  £160
1 3/4 coated header  £170
Also have merged single and Dual Quiet Packs available.
O/FF 88
12.66 @ 98mph at Garys picnic 31/5/10
Jonny Grigg
« Reply #20 on: September 28, 2010, 22:07:29 pm »
Hi Jo,
Do you have a Hurst Line Loc for sale still?
Cheers,
Jonny.
No Compromise. O/FF111
« Reply #21 on: September 28, 2010, 22:15:22 pm »
Hi Jo,
Please see a PM from me.
Best rgs
Kalle
« Reply #22 on: September 28, 2010, 22:34:08 pm »
PM for Line-Lock
« Reply #23 on: September 29, 2010, 16:32:50 pm »
Hi Jo, PM and Paypalled.
tikimadness
« Reply #24 on: September 29, 2010, 21:40:20 pm »
Does the turbo have a carbon seal?
Thanks Michael
NIDGAFWYT
Jo Clifford
« Reply #25 on: September 29, 2010, 21:56:40 pm »
Thanks Michael
No it does not
Jo
Jo Clifford
« Reply #26 on: September 29, 2010, 21:59:22 pm »
Turbo is pending Glenn C Smiley
thankyou
Jo
henk
« Reply #27 on: October 21, 2010, 10:40:52 am »
hallo,
did you recive my last PM please?
henk!!!
Jo Clifford
« Reply #28 on: October 21, 2010, 18:51:04 pm »
hallo,
henk!!!
Yes
and replied,
thankyou
Jo
Jo Clifford
« Reply #29 on: December 16, 2010, 17:02:49 pm »
We now can offer parts from "Fast Fab" these are very good quality and we have been using them for over a year now on our own cars.
To begin with we have both Round & Hex T bars,alluminium fabricated breather boxes with both push on and -8 fittings,collapsable push rod tubes and fuel pump block offs with& without a threaded hole for a breather fitting,all parts located in england
Jo
Pages: [1] 2 Print
