June 10, 2026, 14:32:01 pm
352171 Posts in 28909 Topics by 6919 Members
Latest Member: mvptkfjb
| | |-+  Why is the Cal-looker lowered up front?
Author Topic: Why is the Cal-looker lowered up front?  (Read 15080 times)
« on: April 21, 2006, 10:30:47 am »
Any physics gurus here that can explain this to me?
My guess history wise is that the street boys looked at the gassers at the time and just mimicked what they did...
But is it just a look thing or what?
SOB/RFH
Have fun!!
« Reply #1 on: April 21, 2006, 21:35:26 pm »
Back in the day i presume that if you built a full tilt race car and drove it on the street....it sort of resambles a race car. All race cars at that day had lowered fronts, opposite to the "normal" gassers of the same time that had raised fronts to raise center of gravity and add to the hook of the car as it came of the line. Anyway knowledge was high and experimenting was legio. I think that Inch Pincher one set a lot of the pace though...the front end just got lower and lower as time went. UnderDog and Dirty Dave Vanderberke are two more examples of gassers with street chassies making wheelies and went quick on the quarter mile. Just rambling a bit about the issue.......
« Reply #2 on: April 24, 2006, 23:04:41 pm »
Well rambelings is much better than nothing...  But the fact remains.. how to hotrod still claims that you should go with a taler front than rear..   Lips Sealed
Gunnar|Rennfahrer
« Reply #3 on: April 24, 2006, 23:32:54 pm »
I think that is because of the caster, and to get rid of positive camber wich really make a car unstable in higher speeds.
Just a little bit negative or 0 camber makes a big difference compared to positive camber.
Also stated in How to hotrod, GET A CAMBER COMPENSATOR! only problem I don't like the new ones. Better make my own..
Gunnar
Rennfahrers VW Club
SilverPig
Alles klar?
« Reply #4 on: April 25, 2006, 09:14:08 am »
It could ave something to do with aerodynamics...if that was invented back then  Wink A lower front will decrease amount of air slipping underneath the car, decreasing lift from the ground. The lower nose will also give the car a more streamlined shape.
Say hello to my little friend!
« Reply #5 on: April 25, 2006, 10:43:10 am »
Guys...you`re all far out here! The reason for our low noses is very simple and very logical;  you rake your car so that you constantly need to hold both hands on the steering wheel  keeping you from slipping out of the seat. This way you`re constantly on the alert and awake and have both hands on the wheel which is safe according to the "rules"   Cheesy
Best rgs
Funny man BeetleBug
« Last Edit: April 25, 2006, 13:43:18 pm by BeetleBug » Logged
Grelland
« Reply #6 on: April 25, 2006, 23:12:41 pm »
the answer is simple: looks good....
___________________
Roy
fast54vw
« Reply #7 on: April 28, 2006, 07:15:28 am »
i think everyone is right but i do have to agree with Grelland. it does look good
« Reply #8 on: April 30, 2006, 09:48:16 am »
this's the right stance  Cool this's scott baken cal look when he was in the DER SELTEN KAFER VW KLUB
« Reply #9 on: April 30, 2006, 10:00:24 am »
another great cal look from the 70's  kris klingaman here's the car in cal look   before its reconvertion in drag
« Reply #10 on: May 05, 2006, 02:55:36 am »
I couldn't agree more Smiley
