September 23, 2026, 21:25:25 pm
| | |-+  firestone 135's on brm's
Author Topic: firestone 135's on brm's  (Read 6788 times)
beetletom
« on: June 24, 2010, 17:08:07 pm »
any pics??
as my puma beam only goes so low, and my current steels and 135 smart car tyres, leaves quite a big gap!
i think the firestone 135 f560's are a bit taller?
« Reply #1 on: June 25, 2010, 03:08:01 am »
Why not 145`s? They handle and stop way better than 135`s.
beetletom
« Reply #2 on: June 25, 2010, 09:40:00 am »
i had some 145 f560's on a set of brm's i had a few years ago, looked too big
was thinking if i fitted 135's it would give a bit more stretch
Kaferdog
« Reply #3 on: June 25, 2010, 09:53:48 am »
Here's a shot for ya ..... Wink
« Reply #4 on: June 25, 2010, 10:22:26 am »
What make of BRMs? Flat 4 ones are 5" wide, MWS are 5.5". If you've got the MWS, you'll need the 145s. You could get away with the 135s on the Flat 4, but I wouldn't. I've got 145 Michelins for my Flat 4's - I prefer the sidewall to the Firestones.
qubek
« Reply #5 on: June 25, 2010, 15:34:34 pm »
I would not use 135s on my Beetle anyway - it's too narrow, but there is no problem with using 135/80 tyre on a 5,5 inch wide reams.
beetletom
« Reply #6 on: June 26, 2010, 09:43:35 am »
ok thanks, yep mws
rebel
« Reply #7 on: June 27, 2010, 23:18:13 pm »
Did you try?
benssp
www.callookvw.com
« Reply #8 on: June 30, 2010, 22:02:51 pm »
I'd go with 145's on the front, go as wide as you like on the back Grin
www.vwheritage.com  My Job
YMCA
bodgit
« Reply #9 on: July 01, 2010, 12:07:23 pm »
I concur Grin
Matt
« Reply #10 on: July 01, 2010, 18:10:40 pm »
135's look and work best on 4- 4 1/2" wheels.
qubek
« Reply #11 on: July 12, 2010, 15:09:38 pm »
Did you try?
I tried 135/70 on a 5,5 inch rim. If this works, than 135/80 will be ok too.
