October 04, 2026, 06:28:35 am
Differential identification
Topic: Differential identification (Read 8293 times)
Kaferdog
June 27, 2010, 23:07:09 pm »
I'm would like to find out any info on this differential ..I picked up this tranny and don't know much about it I would like to see what it is ...Hopfully someone can tell me ..?......
Re: Differential identification
June 28, 2010, 03:40:00 am »
Bruce should be able to ID the tranny, cool side plate for sure. Wonder what make is that.
June 28, 2010, 06:20:24 am »
That would be a swing axle differential.
That side cover is a cool item. The center part is made from a stock Mg side cover, and the outer part is steel.
Kaferdog
June 28, 2010, 06:45:58 am »
Bruce...can you tell me who it's made by...?... kinda curious who the makers is...?
June 28, 2010, 09:29:19 am »
The 'box started life as a 1970-on Karmann Ghia case, with a 4.12 R&P. I'd guess with a sideplate like that that it's not stock any more though - could be anything inside it!
June 28, 2010, 16:18:38 pm »
Quote from: Kaferdog on June 28, 2010, 06:45:58 am
Nope. Nobody else could either. Take it apart, then ask the question.
June 28, 2010, 17:27:21 pm »
Bruce, I think he ment the sideplate, who made a plate like that? Is that considered stronger to whats out there now?
Ted
June 29, 2010, 05:34:41 am »
The topic's title says different.
Kaferdog
June 29, 2010, 09:11:04 am »
Quote from: Neil Davies on June 28, 2010, 09:29:19 am
Neil,
thanks for sharing your knowledge I appreciate it I'm just trying to find out what I have here..?...I don't know how to distinguish "Sideplate" from "differentials" I guess....My bad..!
June 29, 2010, 09:15:04 am »
Quote from: Kaferdog on June 29, 2010, 09:11:04 am
Neil,
No worries, just knowing where to look is part of the trick!
http://www.vwheritage.com/ssp/Vehicle-Part-Information/Engine-Gearbox-Codes/?templateID=ssp
Kaferdog
June 29, 2010, 09:22:38 am »
Quote from: Neil Davies on June 29, 2010, 09:15:04 am
Neil,
Neil..Thanks Now I'm headed in the right direction....Thanks again ...!!!
mcmscott
June 30, 2010, 00:57:14 am »
Transform,from Long Beach(no longer in bizz) made that side cover
June 30, 2010, 01:38:56 am »
I remember them, bought a trans from them a long time ago. How good is that side cover compaired to today sidecovers? I talked to Kaferdog, and he is interested in knowing about the side cover also, just didn't add it to his original post. Very curios on how they did the mating of the two pieces.
Ted
Kaferdog
July 03, 2010, 07:47:46 am »
Quote from: mcmscott on June 30, 2010, 00:57:14 am
You were right on the Money..!!!! "Transform"....!! ..How good is this Diff...? anyone have a idea ?
Ron Greiner
DKP II
July 08, 2010, 23:54:17 pm »
the diff I saw in a transform trans was really bad, those welds were actually brazing, the one I took apart had cracks in those brazing welds and was less the 6 months old
Billyisgr8
July 09, 2010, 04:01:57 am »
Mine has lasted very well in my drag car. I have the same one but IRS. It has been 11.2 @ 120 so far in the 1/4. over 150 slick launches, 60 low to mid 7 passes 1/8 mile, 90+ 8 to 9 second 1/8 mile passes, 4 years in a superbeetle running high 14's, countless 2nd gear street burnouts, clutch dumps, then put it in my current singleport dragcar. 3rd gear broke before the superdiff has. I have not had any problems with it since making it a full time drag street car that weighs 1850 pounds 5 years ago.
I have heard lots of negative about this diff, I will take pictures of mine when it comes apart, cause I am curious as to how well it has held up to wear.
Kevin
Last Edit: July 09, 2010, 04:08:01 am by Billyisgr8
Kaferdog
July 09, 2010, 16:51:46 pm »
Thanks Guys ...!...I picked the trans really cheap...! just wanted to know if it's worth keeping..?
