November 04, 2026, 22:04:19 pm
40 p11's on Gene's manifolds and cool linkage.
Topic: 40 p11's on Gene's manifolds and cool linkage. (Read 8543 times)
Geoff P DVKK
June 28, 2010, 00:46:37 am »
With all the chat about 40 p11 carbs in another thread I thought i'd dig out a set I have and find out a little more info.
This is a complete kit with all linkage, fuel lines, shroud and Gene's manifolds.
The carbs are a total loss but could be used for some small parts. Linkage still works smooth and tight. My question is, was this a kit offerd by Gene back in the day or was this linkage some other make? From what year roughly?
I see Sarge had the same manifolds.
Gene's manifolds
Fuel lines
Last Edit: June 28, 2010, 00:48:31 am by Geoff P DVKK
Mike Maize
Re: 40 p11's on Gene's manifolds and cool linkage.
June 28, 2010, 01:21:26 am »
Hey Geoff, I am pretty sure my friend John is running that exact same set up on his old school roller crank engine. I will get some pictures next weekend. I thought the shroud was 356 stuff?
Geoff P DVKK
June 28, 2010, 01:48:11 am »
I was thinkin 356 as well
June 28, 2010, 02:59:04 am »
Cool old stuff and I think its 356 to.
Dave Galassi
June 28, 2010, 03:09:55 am »
The linkage is 356. Ironically, I was synching the carbs on my neighbors 356 and came home to see this thread. Same linkage. Those must be the only set of P11's I know of that don't leak through the throttle shafts..................
Last Edit: June 28, 2010, 14:01:07 pm by Dave Galassi
June 28, 2010, 03:34:07 am »
The linkage is for a 356/912, but the shroud itself, not sure, the bottom piece for the linkage is riveted on, I believe they are spot welded on originally. But it's been awhile since I built a 912 motor. Cool set-up though.
Ted
June 28, 2010, 13:53:24 pm »
That fan shroud looks VW to me and the pop rivets holding the linkage to the back don't look too official. 356 / 912 cylinder tins are in four pieces and come up higher on the fan shroud, too. As for the linkage, that looks like Porsche stuff adapted to a VW shroud with the fan velocity ring thrown on for good measure. Gene's linkage has always been basically the same as far as I can remember... much like it is today only way simpler in the early days. The manifolds I had were made of magnesium and shined up nice after the metallic blue paint was striped off. I remember all the "fun" I had changing spark plugs with those shorties...
Last Edit: June 28, 2010, 14:04:13 pm by Sarge
July 01, 2010, 17:54:27 pm »
Sarge has it. That's an early 40hp shroud with the 356 linkage & venturi ring added on. I wanted to do that linkage to AssHull's shroud, but he already has Berg linkage, I feared the behind-the-shroud linkage would interfere with the T4 cooler, and his shroud has already been through enough welding!!
The square detent at the top of the VW shrouds I always presumed was for oil bath air cleaner clearance... so why was it on the Porsche shroud as well??
July 01, 2010, 22:23:56 pm »
Quote from: Zach Gomulka on July 01, 2010, 17:54:27 pm
I think for industrial applications (single carb Porsche)
Chris W
July 01, 2010, 22:53:04 pm »
Thats a cool fuel line T also!
July 02, 2010, 03:21:35 am »
Quote from: cosmic charlie on July 01, 2010, 22:23:56 pm
Ahhh... forgot about those.
kingsburgphil
July 02, 2010, 05:44:13 am »
Just for the sake of conversation.
Pic stolen from
http://www.356a.com/engine_identification.htm
