September 25, 2026, 05:46:37 am
| |-+  For sale!
| | |-+  CSP rear disc brake kit 5-205 -67 RACE
Author Topic: CSP rear disc brake kit 5-205 -67 RACE  (Read 2824 times)
Gunter
« on: June 28, 2010, 09:22:05 am »
new at CSP: Product Description:
Our CSP 5/205 rear disc brake system has been strictly developed for drag race use. This system is also installed to our Type-34 race Ghia. The rotation mass has been reduced by about 4,390 Gramm and the unsprung weight by about 6,440 Gramm per side compared to original brake drums.
To get this result the hub has been machined out of solid billet and combined with a highly lightweigthed rotor. The two piece construction results in a track decrease by 5mm per side. This gives more clearance for wider slics under the wings.
The caliper brackets has been machined out of a T7075 billet and combines the bracket and wheel bearing cover in one piece. It is also prepared for any wheel sensors that might be required by Racepak Data-System. The two-pod alloy callipers are used.
The kit comes with the familiar high quality fitting hardware.
do not hesite to contact me for all further information (gh@csp-shop.de)
Phil West
« Reply #1 on: July 04, 2010, 07:21:47 am »
Hi Gunter,
Do you have a total weight for one side i.e. hub/caliper/bracket/fixings.
Phil
