September 15, 2026, 20:50:40 pm
352307 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  wedgemating and balancing in the uk
Author Topic: wedgemating and balancing in the uk  (Read 6371 times)
Rocket Ron
It's old school for a reason
« on: June 29, 2010, 06:40:34 am »
hi guys
anyone know where I could get a crank and flywheel wedgemated in the uk , it would be great if they did balancing as well
thanks in advance
Regards Ron
13.12 @ 101.84
Grooving out on life
« Reply #1 on: June 29, 2010, 08:11:31 am »
Don't think there are any, Jick looked into this a few years ago, but it might be worth trying Taylor Machines Services.
Jim @ Stateside does balancing to zero, better than needed Smiley
Fasterbrit
« Reply #2 on: June 29, 2010, 08:40:16 am »
I am sure Taylor would be up for just about anything so give him a buzz re wedge mating. Jmr is awesome for balancing to beyond F1 spec.
www.air-kraft.com
www.marcomansiperformance.com
Martin Greaves
10.88@128.58
« Reply #3 on: June 29, 2010, 13:07:22 pm »
Ron i will call you later about it i have someone who can do it.
Rocket Ron
« Reply #4 on: June 29, 2010, 17:59:30 pm »
cheers guys, that gives me a few options  Wink
13.12 @ 101.84
flatfire
« Reply #5 on: June 29, 2010, 23:35:08 pm »
Its a morse taper. I have a DPR crank and flywheel and have just put it together. On the flywheel it tells you what shims to install to get the desired end float.
I used the info and set my end float it was spot on.
A good machine shop should be able to do it but setting up probably would be a pain.
« Reply #6 on: July 01, 2010, 12:18:10 pm »
Yes it's a morse taper...  with a BIG difference, it has a end stop. Normally when you fit some to a morse you push it as far as it would go that ensures that it sits with the maximum clamping force.. there is no end stop to the taper. On the crank you want the morse to grip the crank at the precise moment when the crank bottoms out in the flywheel, so you have good friction there as well. Get the dimensions on one or the other surface a fraction wrong, and one of two areas of friction stops doing anything. This job is best left to magicians.
« Last Edit: July 01, 2010, 12:31:23 pm by JHU » Logged
Jee Ent.
« Reply #7 on: July 01, 2010, 15:39:36 pm »
I have done it  Cheesy It took a lot of time and measuring. But it's very doable if you have the right tools.
I use a 3degree taper. The taper starts locking 3mm before it meets the flywheel. It needs about 200Nm to get to bottom.
Tried several options when welding the flywheel. Tig and "stick"welds with "special" Esab-additives  made to much heat, and warped it. So I ended up with the good old Mig/mag with low heat and preheated flywheel. The key is to weld very precise, and with continuous speed.
It has been on/off 10 times already. Only minor distortions on the taper. Nice clean surface all the way around.
Try it.. It's fun. But make sure to have some flywheels in spare  Tongue
flatfire
« Reply #8 on: July 03, 2010, 00:23:39 am »
I totallly  agree get the magicians to do it. I was impressed with the combination of the taper and the exact calculation of the shims.
There is an other method called weld mate. An interference fit between flywheel and crank.
