September 22, 2026, 16:18:31 pm
| |-+  For sale!
| | |-+  1965 Cal Look VW – new price
Author Topic: 1965 Cal Look VW – new price  (Read 22602 times)
« on: July 16, 2010, 11:36:02 am »
Don't want to sell, but realistically with the house needing so much work and other 'stuff', somebody's chance to own a very highly-spec'd California Look sedan. Registered in the UK, so no import duties and shipping costs. Why buy from the USA with the exchange rate as it is when you can own the only European-based Looker ever to make it to US Bug-In, VW Classic and the Cruise Nights… Only ever appeared at European Bug-In once, and two small local shows in the UK. Has 1870 miles on its since hitting the road, of which 850 miles were added in California this year!
1965 sedan, originally supplied by California dealer.
Subject to full body-off repaint (only needed a battery tray and one bumper mount) prior to repaint inside and out in Laguna Blue, a 1970 Karmann Ghia colour.
Chassis painted in two-pack gloss black etc.
All new trim, headlights, Lucas turn signals, T-bars etc.
NO RUST! Very straight bodywork...
Interior:
Cobra RS seats on VW subframes
Nardi 'signature' steering wheel
AutoMeter Ultra-Lite 'Monster' tach with shiftlight and recall etc on billet mount
AutoMeter Ultra-Lite oil temp and pressure gauges
Glovebox signed by several of the 'legends' including Darrell Vittone, Ron Fleming, Anderson Brothers etc
Vintage Speed billet shifter custom-made for me to suit Berg five-speed
Handbrakelever  modified to work as staging brake/two-step switch
New Simpson four-point harnesses on both seats
Ron Lummus DRKC chrome-moly roll-cage with door bar
Rear seat delete
New door panels, headlining, carpets, rubber mats etc
Engine:
2332cc
Gene Berg 84mm wedgemated forged crankshaft
Carrillo 5.6in con-rods
J&E slipper-skirt pistons
Century cylinders
Engle FK-10 cam
Udo Becker tool-steel lifters
Autolinea aluminium crankcase
Berg oil pump
Moroso filter head with pressure relief and drain back to sump
Berg oil sump
JayCee pushrod tubes
Berg pushrods
Berg 1.5:1 rocker arms
Berg dual springs
Jeff Denham 043 cylinderheads with 42 x 37 valves
10.0:1 compression ratio
Kennedy Stage 2 clutch
Berg dual-friction centre plate
Art Thraen-modified 48IDA Webers
New-style Gene Berg linkage
New alternator just fitted
CSP breather system
Full MSD 6AL Digital Plus ignition
MSD billet distributor
Rare VW Puma fan shroud
Braided-steel hoses throughout
Remote oil cooler with thermostatically-controlled fan alongside gearbox
Saco upper and lower pulleys (expensive!)
JayCee red-anodised billet timing pointer, jet covers and coil mount
Guesstimated 200+bhp
Transmission:
Gene Berg five-speed built by Mike Herbert of Rancho Performance in SoCal
FTC mainshaft
Weddle 3rd/4th gears
3.78; 2.35; 1.58; 1.21; 0.89
Klinkenborg 3.88:1 ring and pinion
Quaife limited-slip differential
JayCee chrome-moly pinion bearing support
H/D pinion retainer
Sway-A-Way race axles
Wheels etc:
JGE Torker with 145x15 and 205/70x15 tyres
VW drum brakes fully rebuilt – all new throughout
Hurst line-lock
Braided hoses etc
Etc,:
JayCee springplate retainers
Sway-A-Way adjustable springplates
Axle limiting straps
CSP 'torque bar'
Berg solid trans mounts (with weld-in middle mount)
Grant fuel pump
Restored 'Cotton Goff' licence plate surround (TLF25 plate not included – too sentimental to let go!)
New glass
Lexan rear screen (lightweight)
Basically everything new...
Car is currently on its way back to the UK – should be here early August. I will then have the fuel tank repainted (a fuel leak affected the paint round the sender) and supply it with 12 months MOT.
The cost to build a car to this spec doesn't bear thinking about. £18.5K – or trade plus cash.
And no, the DKP badge and decals are not included… Cheesy
« Last Edit: July 27, 2010, 18:23:36 pm by Fastbrit » Logged
« Reply #1 on: July 16, 2010, 18:55:05 pm »
Keith you have made a school boy error, sell the house and live in the car.
Cog
« Reply #2 on: July 16, 2010, 18:59:14 pm »
Wow! Only just recently read about Bluey. Im only a few miles away from you but dont have that sort of budget. Good luck with the sale.
'54 Oval
'56 Oval
'65 Cab
'65 KG
Randy Jewell
« Reply #3 on: July 17, 2010, 09:48:32 am »
Bummer Embarrassed
vwhelmot
« Reply #4 on: July 17, 2010, 16:56:53 pm »
£19.5 k     and no pedal rubbers!   Grin
« Reply #5 on: July 17, 2010, 17:44:44 pm »
I'll throw some in for free… Wink
Gunter
« Reply #6 on: July 17, 2010, 21:04:55 pm »
Keith, good luck with the sale
Gunter.
« Reply #7 on: July 17, 2010, 21:56:43 pm »
Sweet car  Cool
« Reply #8 on: July 18, 2010, 07:07:16 am »
« Last Edit: July 19, 2010, 11:49:09 am by nicolas » Logged
« Reply #9 on: July 18, 2010, 08:40:25 am »
350-year old houses are bottomless pits!
« Last Edit: July 19, 2010, 13:07:12 pm by Fastbrit » Logged
« Reply #10 on: July 18, 2010, 08:51:29 am »
Grin Problem is, houses not selling and mine needs too much work doing to be able to sell, anyway.  Sad
« Reply #11 on: July 19, 2010, 07:55:16 am »
« Last Edit: July 19, 2010, 11:48:46 am by nicolas » Logged
Doktor
« Reply #12 on: July 19, 2010, 11:23:26 am »
Are you a highlander ?  Grin
dr.aircooled
« Reply #13 on: July 27, 2010, 18:24:04 pm »
TTT  Smiley
Bill Schwimmer
« Reply #14 on: July 29, 2010, 20:46:19 pm »
"I've lost count of the number of times I've thought: " I wish I hadn't sold that"...  Keith Seume UVW Feb 2007
    Eddy Merckx
rebel
« Reply #15 on: July 29, 2010, 23:03:41 pm »
Sorry to hear that, KS...
« Reply #16 on: July 29, 2010, 23:21:55 pm »
I know, I know…
deano
« Reply #17 on: July 30, 2010, 05:20:33 am »
Shame old man.... If you sell bluey, I get the glovebox....
Anglia Obsolete Guru
'67 Heaven
Bill Schwimmer
« Reply #18 on: July 30, 2010, 06:21:46 am »
I know, I know…
I hope it all works out , you gotta do what you gotta do,I had some house stuff go sideways last month & it cost much more than I was expecting.
    Eddy Merckx
deano
« Reply #19 on: August 01, 2010, 05:49:51 am »
Ah, the good ole days....
'67 Heaven
deano
« Reply #20 on: August 01, 2010, 17:34:51 pm »
Still more great moments in Bluey's history....
'67 Heaven
« Reply #21 on: August 02, 2010, 20:30:01 pm »
Happy days!  Smiley
Wout
« Reply #22 on: August 02, 2010, 21:31:56 pm »
Keep the car and let it wait untill the house is ready! No brick is worth selling a lovely bug  Roll Eyes
Anyway if there's no other way, good luck with the sale!
gr
Wout
Aircooled vw's for life!
Joe_G
« Reply #23 on: August 31, 2010, 18:37:28 pm »
And now back on UK soil, or was it off on it's hols again??  Wink
« Reply #24 on: August 31, 2010, 18:47:01 pm »
No, at long last, back home. Collecting Bluey tomorrow... LONG drive to Chatham and back from Cornwall! Roll Eyes Cheesy
WayneMcCarthy
« Reply #25 on: October 05, 2010, 20:01:20 pm »
I Just Love this Car ! Is Bluey Back Home in The UK Now Keith ?
« Reply #26 on: October 05, 2010, 20:15:41 pm »
Yes. Phew! Roll Eyes Smiley Smiley
Just waiting to take down to Ben's to do the couple of little jobs I want to do and then...  Huh
House still needs work! Sad
Wout
« Reply #27 on: October 05, 2010, 20:28:51 pm »
If it wasn't that far, I could help you on the house so you could keep the car  Grin
gr
Wout
