October 13, 2026, 20:03:59 pm
Formel-V tool steel lifter 58 gram incl. bushings for Type4 / WBX
Topic: Formel-V tool steel lifter 58 gram incl. bushings for Type4 / WBX (Read 2534 times)
exportbug
July 27, 2010, 06:27:25 am »
Lightweight lifter out of high quality tool steel, hardened and nitride.
Body proportions like Type1 lifter, plate diameter 26mm.
They have no tend to pitting! The lifter are compatible with all steel or hard welded flat tappet cams.
Plus a set of lifter bushings for type4 and WBX to use this lifter in this motor case
The lifter bushings you need, to use the Type1 lifter into an Type4 or WBX engine.
To install the bushings, they only press into the original lifter bore. After this, they not need to drill, inner diameter is ready!! Only the lifter bore dome have to should be lowered 5-7mm
The bushings are CNC produced out of aluminum.
Installation note: Engine case / lifter bore, heat up to 80°C, oil the bushings and press in, ready!
Price: 299,- EUR (set of lifter and bushings together)
Last Edit: November 15, 2010, 20:23:13 pm by exportbug
More information's on
www.tp-technologie.de
