September 28, 2026, 15:05:02 pm
Another belgian late looker
Topic: Another belgian late looker (Read 220927 times)
volkskris
July 27, 2010, 08:49:19 am »
Here is my first car! I got it from my parents on the 30 of June. they bought it six months ago without telling me
I already stripped the interior and body, removed the speedometer cable, electricity of the motor, etc.
I just need to remove the bolts that keep the body on the chassis.
Last Edit: May 29, 2018, 14:15:55 pm by volkskris
volkskris
Re: mexicano
July 27, 2010, 08:54:58 am »
And here are some influences for this car
Last Edit: December 23, 2014, 20:45:07 pm by volkskris
Re: mexicano
July 27, 2010, 11:21:19 am »
Cool
Should become very nice!
volkskris
Re: mexicano
July 27, 2010, 11:29:42 am »
Quote from: Peter on July 27, 2010, 11:21:19 am
Cool
Sure!
but I'm really doubting about the rear lights. keeping the elephant feet or putting earlier lights on.
my fenders and lights are in good condition, that's what makes it so hard.
Last Edit: December 23, 2014, 20:46:21 pm by volkskris
Re: mexicano
July 27, 2010, 11:32:43 am »
put on earlier lights if you can and possibly fill the "ears" behind the quarter windows.
should come out nice with inspiration like that
DVK ~
Wünderwolff
aka Dr. Jeckill
Re: mexicano
July 27, 2010, 11:48:52 am »
Even though I'm not too much of a fan of the big Elephant feet rear lights, I'm even less of a fan of aging a car.
Mind you I do like to cut my cars up, I love that custom touch. But the biggest faux-pas most of us have ever made (car-wise
) is to have made it look older than it really is. Just ask Dem/Wolfwest, one of the nicest lookers in the WW and still he would have gone late if he was to do it again.
So keep the Big lights. Do weld up the ears (but keep the half moon crescent). The first white car is a great example of how it could look.
Wünderwaffe are Go!
volkskris
Re: mexicano
July 27, 2010, 12:32:47 pm »
Quote from: Wünderwolff on July 27, 2010, 11:48:52 am
I actually meant converting to the "churchwindow" rearlights as on the blue car above, the rest (hoods, headlights) will stay the same.
and I think the ears will be fillled, I only doubt how. completely remove them is very complex, while just welding a plate in place of the vents is much easier.
Last Edit: December 23, 2014, 20:47:07 pm by volkskris
Re: mexicano
July 27, 2010, 17:06:18 pm »
exactly, i don't think just changing the elephants to churchwindows is a biggie.
DVK ~
Re: mexicano
July 27, 2010, 17:22:02 pm »
Quote from: 67-indeed/DVK on July 27, 2010, 17:06:18 pm
I agree. It's easily reversable, as well.
kev d
Re: mexicano
July 27, 2010, 19:36:06 pm »
You've picked some cool cars for inspiration
I'd have to say ditch the elephants foot lights though
Cheers,
Kev
wolfswest
Re: mexicano
July 27, 2010, 19:58:12 pm »
churchwindows would suit the car very well and that's okay to do in my opinion. There are cars that are exactly like the look you want, only built in another year, so no problem there...
Please do not remove the ears, it will be a lot of work, it will not be original and before you know it you end up like me. take this advice from an older man
don't do it. I've painted my ears and I think I've created a nice look... nice result and simple to do.
Dem
volkskris
Re: mexicano
July 27, 2010, 21:18:03 pm »
Today the body and pan were split.
The body was welded to the pan at the left jackstand.
Luckily that was the only place.
Last Edit: December 23, 2014, 20:48:44 pm by volkskris
volkskris
Re: mexicano
July 27, 2010, 21:20:51 pm »
Quote from: Zach Gomulka on July 27, 2010, 17:22:02 pm
But it's the costs aspect. I'm on a very limited budget
. I think I'll keep them for now, I can change them later on.
Last Edit: December 23, 2014, 20:49:13 pm by volkskris
Re: mexicano
July 27, 2010, 21:56:35 pm »
that's perfectly acceptable. go with the looks of the white thai car then
DVK ~
Re: mexicano
July 27, 2010, 22:00:43 pm »
Nice project ! Keep the elephant lights, I love the white bug on your previous post.
volkskris
Re: mexicano
July 30, 2010, 10:45:08 am »
Yesterday and the day before I worked on removing the electricity out of the body. Removing the electricity from the engine and rear light was very difficult, but finally I got it out.
I also removed the rear hinges, and the glovebox with front lock.
Last Edit: December 23, 2014, 20:49:41 pm by volkskris
volkskris
Re: mexicano
July 30, 2010, 10:46:52 am »
volkskris
Re: mexicano
August 04, 2010, 11:04:02 am »
The body rests now on a frame, and I bare-metalled some areas with rust.
Today I'm going to remove the crap from the inner wings.
Last Edit: December 23, 2014, 20:50:39 pm by volkskris
volkskris
Re: mexicano
August 27, 2010, 22:16:26 pm »
Finally a new update after 3 weeks
I bought a 1969 shell today, which is much better than what I have now.
It still needs a bit welding in some places, but it's much less work than the mexican shell.
I stripped the pan too, just needs cleaning up the underside.
Last Edit: December 23, 2014, 20:51:39 pm by volkskris
volkskris
Re: mexicano
August 27, 2010, 22:18:25 pm »
Does somebody know how to safely remove the springplates and get them back on?
Last Edit: December 23, 2014, 20:52:03 pm by volkskris
beetletom
Re: mexicano
August 28, 2010, 17:14:22 pm »
Quote from: volkskris on August 27, 2010, 22:18:25 pm
does somebody know how to safely remove the springplates an d geet them back on?
yep, undo the 4 15mm bolts
remove the outer rubber bush
mark 2 or 3 lines on the springplate and torsion bar
then get 2 lever bars, to remove the springplate off of the torsion bar, and try not to pull out the bar itself
Speed-Randy
Re: mexicano
August 28, 2010, 22:37:40 pm »
better yet, after removing the hardware, use a turnbuckle from the holes at the back of the springplate to the shock tower and this way you dont break your fingers or your tools. MUCH SAFER AND EASIER THAN PRYBARS
www.vdubspeedshack.com
volkskris
Re: mexicano
August 29, 2010, 21:21:26 pm »
Thanks all for the replies, I'll see what I'll use.
Last Edit: December 23, 2014, 20:52:36 pm by volkskris
volkskris
Re: mexicano
August 31, 2010, 21:39:32 pm »
So I picked up the new body today
. It still needs work, but it's a lot better than what I had.
Last Edit: December 23, 2014, 20:52:58 pm by volkskris
volkskris
Re: mexicano
August 31, 2010, 21:40:13 pm »
Re: mexicano
September 13, 2010, 14:20:40 pm »
happy birthday!
any progress on the project?
DVK ~
volkskris
Re: mexicano
September 13, 2010, 16:44:24 pm »
Quote from: 67-indeed/DVK on September 13, 2010, 14:20:40 pm
happy birthday!
Thank you!
Well, not a lot. I removed most off the filler from the left side behind the door, at some places there was like 1 cm of it
there was some more cleaningwork, and that's all I (and my dad) did. I'm in the last, busy, year of secondary school so progress wont go as fast
I'll keep you posted when their is an update.
Last Edit: December 23, 2014, 20:54:49 pm by volkskris
volkskris
Re: mexicano
September 14, 2010, 21:56:23 pm »
Today I picked up a rustfree engine lid (without vent holes) for 25 euros. That saves me the useless work to a rusty one.
Last Edit: December 23, 2014, 20:55:35 pm by volkskris
volkskris
Re: mexicano
September 20, 2010, 20:46:41 pm »
Went for 2 rustfree doors today. They came with all the window crap, and a talbot mirror.
The chrome around the windows is already black, a thing i won't have to do now
Last Edit: December 23, 2014, 20:56:48 pm by volkskris
volkskris
Re: mexicano
Reply #29 on:
October 28, 2010, 21:48:03 pm »
Dusting off this thread for an update...
I got a new pan, which suffered from some transportation damage, but was perfect otherwise.
The damage is already repaired by a friend of my father.
It's perfectly straight now.
The body I bought will not be used, but cut up. The reason it won't be used is because the doors don't fit.
I'll use some parts for my old body, and sell the other good parts.
Pics will come later...
Kristof
Last Edit: December 23, 2014, 20:57:37 pm by volkskris
