September 12, 2026, 11:49:20 am
352303 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Can this gap sty there or should it be removed?
Author Topic: Can this gap sty there or should it be removed?  (Read 5046 times)
red baron
« on: July 27, 2010, 23:45:05 pm »
Hey guys,
I'm currently finishing my longblock and now its time to care about the heads. I wonder if this gap should be removed, that is around the combustion chamber?
I will probably using shims to get my compression ratio and my 1.5mm between deck height...
« Reply #1 on: July 28, 2010, 02:48:39 am »
How thick is the step?
I'd be tempted to leave it and deal with it.
What's the chamber size with/without the step (could be difficult to measure without)?
Tom
red baron
« Reply #2 on: July 28, 2010, 07:13:16 am »
The chamber size without should be 50cc . the step is about 1mm high. I measured once and it was nearly 60cc.
« Reply #3 on: August 01, 2010, 12:28:45 pm »
You can "zero deck" the engine, if the I.D of the step is equivallent with your piston size. That works well. If thatīs not a solution, you have to machine the heads conventionally.
red baron
« Reply #4 on: August 01, 2010, 22:52:43 pm »
this gap is like a triangle and get lower on the inside. my concern is, that the cylinders just sit on a line because of that and dont have a proper sealing surface.
I think I will stick to 1.5mm deck height and reach this with shims on the case side.
