November 02, 2026, 23:28:49 pm
Distributor drive slop??
Topic: Distributor drive slop?? (Read 3577 times)
Lanny Hussey
July 28, 2010, 05:17:49 am »
I'm looking for ideas on this one..
I have a recently completed customer car that has an odd issue with a large amount of timing scatter. The crank will rotate 14 degrees before the rotor turns. The distributor is locked(ECU controlled ignition). The drive(German) was pulled out and everything appears fine. Any thoughts? The engine is all over the place whilst cruising. Thanks!
SlingShot
Re: Distributor drive slop??
July 28, 2010, 09:36:07 am »
Was the drive Endplay checked with the case halves split and the distributor installed? I believe .050" is about right?
Will Race For Beer !!!
Jo Clifford
July 28, 2010, 11:42:52 am »
It sound like the brass gear might be going away, seems this is quite common the last year or so.
Jo
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
