September 22, 2026, 19:03:34 pm
| |-+  For sale!
| | |-+  2332cc 11 Second Motor built by Pat Downs, re-built/freshened by Richie Webb
Author Topic: 2332cc 11 Second Motor built by Pat Downs, re-built/freshened by Richie Webb  (Read 5674 times)
Adele AW
« on: July 29, 2010, 13:16:05 pm »
Originally built by Pat Downs in 2008 and re-built/freshened by Richie Webb in Febuary 2010. Since this we have done 15 passes. We change the oil (Millers CFS 10w 60) and spark plugs every race meet, which means the engine runs on fresh oil/plugs every 4 or so runs.
Car was dyno'd in the UK 196BHP at the wheels, which converts to around 230 Flywheel BHP
I have ran a best of 11.23 @ 118.8 MPH in our car which weighs 1684lbs with driver, so is by no means particularly light. We also believe there is more in the motor, i have managed a 1.46 60Ft and this was on a slower run, but we have a few niggles with our suspension, so it is there!
I will sell the motor with or without the EFI, pricing below
If buying without EFI Excluded is:
Throttle Bodies/Fuel Rail/Injectors
Linkage
ECU
MSD Coil Pack
All Sensors
Pulley ( But Similar one will be provided )
Specification:
2332cc
CB Aluminium case, 3.5mm raised deck with modified pick up tube and custom full flow oil system.
10mm Case Savers and 10mm Chromoly Head studs
CB 4 Quart Deep Sump
CB Oil Pump and CB Oil Pump Cover
Jaycee Oil Filter system with external bypass
System 1 Oil filter
CB 84mm Chromoly Nitrided and Wedgemated Crank with 2" Buick Journals
12.5lb Wedgemated Chromoly Flywheel
5.5" CB Chromoly Rods with ARP 2000 bolts
94mm Wiseco Pistons ( Teflon Coated )
Engle FK89 cam
Scat Lightweight lifters
CB CNC Ultra Wedgeport heads - 46x37 Ti valves, LS-1 Valve springs, 7deg chevy locks
CB 1.4:1 rockers
CB Welded and match ported manifolds
Kennedy stage 2 clutch with Daiken super disk
Phoenix Stainless steel header and Muffler
CB bolt on Rocker covers with #8 breather fittings
Manton Chromoly Pushrods
Jaycee Billet Push Rod Tubes
Jaycee Pulley
Jaycee Oil filler
Jaycee Fuel block off
CSP Oil cooler block off
13:1 Compression running on VP C12
Also included is any other all of the Oil flow fittings.
Price is £7000 ( Excluding EFI as above )
Price is £8900 ( Including EFI )
We are also prepared to sell as of end of August (4 Weeks) If you are seriously interested then please email me Smiley
« Last Edit: July 31, 2010, 17:09:48 pm by Adele AW » Logged
O/FF 621
Adele AW
« Reply #1 on: July 31, 2010, 17:08:08 pm »
Change to the pricing options
Smiley
O/FF 621
Adele AW
« Reply #2 on: August 11, 2010, 22:20:45 pm »
Up
O/FF 621
SteveW
« Reply #3 on: August 27, 2010, 22:35:07 pm »
 Smiley
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
