September 25, 2026, 03:00:18 am
| | |-+  Awh nut's & wheel studs
Author Topic: Awh nut's & wheel studs  (Read 5265 times)
Black Sheep
less is more
« on: August 01, 2010, 18:21:43 pm »
OK little help here please  Smiley
I'm looking to put some 12mm studs in my drums to bolt some MWS BRM's to .
Found the studs I want no problem but the wheels have 15mm holes for the bolts / studs .
Looking about for some sleeved nuts with a 30 degree washer all I can find are 41/64' bolts which work out at 16.27mm .
Anyone got any idea's as I don't want to run without sleeves and risk the wheels slapping about on the threads .
I'm sure I must be missing something here  Roll Eyes
I've seen guys running what look like a brass looking cadnam plated nut on a stud looks very pro  Cool all I seem to able to find is either silver or nasty chrome  Huh
 HELP  Smiley
« Last Edit: August 01, 2010, 18:23:30 pm by Black Sheep » Logged
13.03 @ 98mph
Gary Justus
« Reply #1 on: August 01, 2010, 20:28:14 pm »
Just curious, why are you using 12mm studs? 14mm would be easier.
Black Sheep
less is more
« Reply #2 on: August 01, 2010, 20:44:12 pm »
Just the size of the drum thread's , never thought about opening them up and using 14mm
13.03 @ 98mph
lofty1971
« Reply #3 on: August 01, 2010, 21:40:47 pm »
14mm stud conversion Glen, Alex has done it on both my cars  Wink
Machine 7 were great when it came to advice on nuts, studs, bolts etc
Black Sheep
less is more
« Reply #4 on: August 01, 2010, 21:53:30 pm »
Bugger CSP rear drum's already came with the 12mm studs fitted  Roll Eyes anyone need 10 x 12mm studs  Cheesy
13.03 @ 98mph
qubek
« Reply #5 on: August 02, 2010, 13:45:02 pm »
I didn't know there is a problem with that. The holes in the wheels are always bigger then the studs thread. It's the nut that holds the rim to the drum. I run my wheels like that.
benssp
www.callookvw.com
« Reply #6 on: August 02, 2010, 14:55:06 pm »
Glenn, MWS wheels have a 60 degree taper on the holes so you don't need sleeved nuts, alternatively get them machined to accept Boom Booms inserts Grin
www.vwheritage.com  My Job
YMCA
Black Sheep
less is more
« Reply #7 on: August 02, 2010, 20:11:55 pm »
Now there's an idea  Smiley
13.03 @ 98mph
