September 22, 2026, 14:56:52 pm
| | |-+  Overflowing carb inlet... bad float/needle valve?
Author Topic: Overflowing carb inlet... bad float/needle valve?  (Read 3743 times)
bugnut68
« on: August 02, 2010, 19:34:00 pm »
Not really cal look, but rather a low-mileage '63 with a 40horse.  Having issues with the car as it sits constantly and rarely if ever gets driven.  Trying to address issues so I can get it cleaned up and sold.  Turning it over, the carb is overflowing fuel out the inlet... is this a sign of a bad needle valve/float?  Thinking a rebuild kit may be in order.
Previously the car would run while on the choke, but not idle off choke.  No intake or vacuum leaks found to date.
« Reply #1 on: August 02, 2010, 21:14:13 pm »
Ryan, pull the needle and seat and spray with carb cleaner and blow it out, test it. If it works, there ya go, if not, rebuilt kit, comes with a new needle and seat. Float, dunk it in solvent, see if it bubbles, also shake it, see if it has gas in it. Have fun!
Ted
