November 02, 2026, 14:04:20 pm
| | |-+  footprint solex 40 p II 4 vs weber idf 40
Author Topic: footprint solex 40 p II 4 vs weber idf 40  (Read 8281 times)
wolfswest
« on: August 03, 2010, 10:38:26 am »
Hi, I have manifolds for the 356/912 carbs and I was wondering if the footprint is the same as a weber 40mm idf carb...
Or do I need to buy another set of manifolds?
thx,
Dem
« Reply #1 on: August 03, 2010, 12:29:49 pm »
You need new manifolds. There are adaptors available, if you can track them down...
« Reply #2 on: August 03, 2010, 12:37:46 pm »
Keith, I think you're referring to IDAs.
I've seen manifolds that take the solex 40 P11 and weber IDFs, but the outer stud is in a different position. basically, these manifolds have 6 studs but depending on which carbs you mount you remove 2 of the outer studs.
wolfswest
« Reply #3 on: August 03, 2010, 12:44:01 pm »
okay, thx guys, I'll check it out as soon as I have the carbs in my possession.
xavier
« Reply #4 on: August 03, 2010, 12:55:56 pm »
This is what you need
Xavier
« Reply #5 on: August 03, 2010, 13:00:06 pm »
Nope. See the above post… Wink
I know about those, but presumably Dem doesn't have them…
« Last Edit: August 03, 2010, 13:02:05 pm by Fastbrit » Logged
wolfswest
« Reply #6 on: August 03, 2010, 13:13:35 pm »
thx guys,
I'm asking these questions for a friend of mine, later this week I have the idf + solex carbs in my possession and then we will see.
the adaptor kit is maybe more expensive then a pair of new manifolds?  where can I buy this adaptor kit?
thx
« Reply #7 on: August 03, 2010, 15:36:19 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=982679
http://www.thesamba.com/vw/classifieds/detail.php?id=1003354
Rick Sadler
« Reply #8 on: August 03, 2010, 17:05:19 pm »
Here is a choice for manifolds or adapters. Check with your local BUGPACK Dealer.
http://bugpack.com/content.php?id=105
« Reply #9 on: August 03, 2010, 17:12:00 pm »
Uncle Rick to the rescue again! Grin
wolfswest
« Reply #10 on: August 04, 2010, 09:46:06 am »
THX guys!!
Soon my friend is ready to go!
