September 22, 2026, 07:09:14 am
| | |-+  Minimum requirements for a cal-look engine
Pages: [1] 2 Print
Author Topic: Minimum requirements for a cal-look engine  (Read 26072 times)
Pekka
« on: March 11, 2007, 09:40:08 am »
OK, before anyone gets any ideas, I'm writing this very much tongue in cheek  Tongue (but still dead seriously)  Grin
I'm trying to build my cal-looker to fulfill the cal-look regulations but I'm on a shoestring budget and have very little extra time too. Family, kids, starting a business etc. you know the drill... As there has been a lot of "that's not cal-look" and "this is not cal-look" comment flying across this board, I'd just want to make sure I'm safe  Roll Eyes
So what in your view would be the minimum requirements for an acceptable cal-look motor?
I sent the club a wire stating, "Please accept my resignation. I don't want to belong to any club that will accept me as a member."
- Groucho Marx
« Reply #1 on: March 11, 2007, 09:54:24 am »
1776 plus twin 40's, this is a minimum.
« Reply #2 on: March 11, 2007, 11:21:06 am »
I think a 1679cc with IDAs would do as well...
Sander/DVK
« Reply #3 on: March 11, 2007, 11:30:07 am »
Minimum 1776cc, thats it.
« Reply #4 on: March 11, 2007, 11:45:55 am »
So you're saying that all the original Cal Lookers, with their 88mm x 69mm engines, were wrong! In reality, a 1679cc (1700) with counterweighted stock crank, stock rods, Engle 110 cam, ported factory dual-ports, Bosch 010 distributor, dual 48IDAs and set of dual quiet-packs would be the archetypal "Cal Look engine" and would cost relatively little to do. And it would look oh so cool...  Cool
« Reply #5 on: March 11, 2007, 11:58:53 am »
Yep Wink Huh
Sander/DVK
« Reply #6 on: March 11, 2007, 12:11:26 pm »
No, not the original lookers, but if you want to built a looker these day's, I think that a 1776cc replacement is a minimum. Thats my thoughts about it Wink
What I try to say is that a 1679cc with 48IDA's is more Old School.
« Last Edit: March 11, 2007, 12:16:00 pm by Sander/DVK » Logged
besserwisser
« Reply #7 on: March 11, 2007, 12:37:15 pm »
A cal-look motor is not judged by size,it´s the attitude that counts. I know of several 1600+ engines with 120+ horses with both ida´s or dellortos. A streetdiven 1600 that is capable of 14sek on the quartermile is cal-look to me. In fact the whole issue of Cal-look is attitude but lately it´s been missconscrewed to some written rules that takes away all the joys of new and exiting ideas. Ther are more than one way of skinning a cat. My personal opinion only.
« Reply #8 on: March 11, 2007, 17:39:37 pm »
The 1600 I built for my '67 gave many bigger motors a run for their money. I dont think displacement has anything to do with it. If you strap 50hp of NOS to a stock engine and that gets the job done for you then that is cool by me. To each his own.
« Reply #9 on: March 11, 2007, 18:29:22 pm »
That's what i meant KS!
That particular setup still appeals to me very much  Grin
Too bad it doesn't count for the 1600 class otherwise i could give those guys some whoopass  Shocked Wink
christophe
« Reply #10 on: March 11, 2007, 22:10:21 pm »
That's one thing I wonder about those "small" engine with 48 IDA on.How was/is the street driveabilty(i'm not sure of this word Roll Eyes)of those engines?
« Reply #11 on: March 11, 2007, 23:11:08 pm »
if i may guess... i suppose they ran small venturis and a w110 will give you quite some bottom end. so i suppose the setup KS mentioned would be fine.
am i mistaken?
« Reply #12 on: March 11, 2007, 23:21:30 pm »
I ran 36 vents in the 44s on my 1600, of course it also had big valve heads, etc. If the stock valve size is retained, then small 32mm vents would be better.
Dokke/DFL
« Reply #13 on: March 11, 2007, 23:22:32 pm »
I don't know about 1679 cc but 1776 cc with IDA's runs very wel en I never had any problems
« Reply #14 on: March 11, 2007, 23:48:22 pm »
You just needs a smaller venturi to create enough vacuum for the carb to work... I wouldn't worry.
Cheesepanzer
« Reply #15 on: March 12, 2007, 02:38:50 am »
When I think of a traditional cal-look engine, with a budget, I immediately think of what's on an engine rather than what's in it.  For example, if you're on a budget, a stocker with some modifications would be considered "cal-look" in my book if it had the following:
header extractor with a single or dual QP
Original Bosch 009 or 010 and blue coil
Santana degree crank pulley
A set of Solex Kadrons
Set of 1.25 rockers and HD valve springs.
This will be a budget engine for sure but shows that you're cal-look and working....
Plus, it will be rock-solid reliable and sound nice.
Good luck and have fun!  Grin
63 Type 2 Single Cab
Cornpanzers
The Ideaman
« Reply #16 on: March 12, 2007, 02:48:57 am »
A few years ago, at the Pomona swapmeet, I bought an unknown engine because it had ida's and Skat Traks on it.  Turns out it was a 1679 with ported stock valve heads and an engle 120.  When we cc'd it out, the little motor had 10.8 to 1 compression ratio.  Cleaned it up, but never ran it.  Wouldn't have run on California pump gas nowadays.  Took it apart, and now pieces of it are in my 2110 and heads are going on my 1776.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
« Reply #17 on: March 12, 2007, 10:40:45 am »
Ward, i'm working on that setup  Wink Grin
Luke, too bad you didn't run that 1679 setup. Were the pistons and barrels machine-in or slip-in? Contact me if you still have some parts lying around...  Wink
I liked Mank's specs a lot as well:
1679cc Engine Specification
AS41 New crankcase
88mm Thick Wall Mahle Pistons and Cylinders
69mm counterweighted crankshaft
200mm, 12lb, 8 doweled flywheel
Engle FK8 camshaft
JMR 044 cylinder heads (40mmx35.5mm), polished and ported
Autocraft 1.4:1 rockers
Berg chromoloy pushrods
Dual 48 IDA carbs on tall manifolds
Berg 26 mm oil pump
Scat deep sump
Berg 440e Equaliser crank pulley
Kennedy 1700lb pressure plate
15/8” Phoenix merged header
2 ¼” muffler (A1)
HP1 Fram external oil filter
009 Distributor
130 bhp@6,000 rpm recorded on the JMR dyno May 1997
Sounds pretty strong!
« Reply #18 on: March 12, 2007, 11:05:24 am »
This is confusing... some say cc is what makes a cal look engine, some mention parts... but no one mentions performance? Isn't the big deal here that the engine has a certain degree of enhanced power pr cc?
So if you have a 1200 with 70 hp that's cal look...
Or a 1600 with 130 hp is a cal look engine....
With this kind of tuning, its impossible to avoid a cal-looking engine.... except if you go with turbo.
alex d
« Reply #19 on: March 12, 2007, 11:09:07 am »
 I don't mind if it is a type 1 or a type 4, if it has IDAs or DCNFs or Kadrons...if it's fast enough to make you smile at every stop light and make the drivers around you go WTF Huh, THEN, it is cal-look,
lowfastbus
WUNDERWAFFE
« Reply #20 on: March 12, 2007, 12:21:38 pm »
I like the 74mm crank with 85.5mm pistons idea alot, so much that I'll be trying it on a engine soon...
Can be done on a very limited budget...( no machining etc...) and you'll end up with a 1700cc engine.
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
SilverPig
Alles klar?
« Reply #21 on: March 12, 2007, 12:25:18 pm »
I'd guess since it's called "cal-LOOK", there has to be some kind of appearance issue in the equation. Otherwise it could have been cal-performance, or cal-speed. That said, the whole idea has to do with whooping some V8 ass at the streetlights, so focusing on the engine is not at all wrong. I like the idea of a small displacement IDA screamer....which means IDA's are minimum requirements for a cal-looker. Amen!
Say hello to my little friend!
« Reply #22 on: March 12, 2007, 14:20:01 pm »
I don't think we're going to agree upon this here  Roll Eyes
Silverpig, sure a cal-look has to have the look. But that doesn't imply that it cannot have the looks AND a nice quick small displacement engine. Sure IDAs are nice, but not everyone can afford them so other carbs can make for a nice alternative.  Undecided
I do however reckon you should at least run dual carbs unless it's a buggy.
Jelle, do you then know where to get a 74mm crank for a limited budget?
lowfastbus
WUNDERWAFFE
« Reply #23 on: March 12, 2007, 19:27:03 pm »
I orderer a DPR rewelded one, really strong and very reasonable priced at 350€ or something like that...
If you're interested in one send me an PM, I like them very much and also use one in my 'big' engine...
WUNDERWAFFE
The Knuckle Buster
quickkafer
German-Pride.com
« Reply #24 on: March 13, 2007, 21:19:31 pm »
I say that it needs to be Type 1 based, and needs to match the understated appearance of the car.  No cosmetic "bling" accessories such as billet or neon dress up parts, and a subtle use of chrome if any.  It needs to look clean!  I know many old school Cal-Look guys that used all sorts of crazy carbs on their engine.  I think the bonding thread is that they (my buddies) were all dual carbed.
If accessorized, I think you've got to look at Santana Pulleys, Race Trim, empi, deano dynosaurs & berg parts from that era.
Type 4 motors, turbos, Nitrous, EFI, are all awesome go fast performance items but not what I consider Cal-Look.
Just 1 man's opinion...  Grin
Scott Faivre
SOB/RFH
Have fun!!
« Reply #25 on: March 13, 2007, 21:31:30 pm »
Guess I am out of the leuge then....I have a type 4 motor....It runs well....It has been alive since 1991 in upgraded forms........It has been  fetured in the mags as a cal-look car a few times..........It runs low 12's and no fockin trailer around it.........It has been street raced regularly...............It look like a type one and has all the concidered richt stuff like Berg linkage, MSD coil and dist..............Hey it can even run on idle for an hour and not overheat...............So if all else is "by the book" I fall out on the fact that I have a type 4 motor, and most of the parts are bought from FAT/Greg Aronson and I even helped them develop a few things....................guess I was wrong!!!!! Shocked
On a positive note. I love to drive my VW with no problems and think that Happiness is a Hot VW!! So the minimum requirement of a Cal-look motor in my book is that it run flawlessly without hesitation, whitout popping, without oil leaking!!! And it does not make a lot of noise...till the butterflies goes WOT!!! Cool
« Reply #26 on: March 13, 2007, 21:55:57 pm »
Hell that lets out about 99.9% of us!  Grin
Jordy/DVK
« Reply #27 on: March 13, 2007, 22:01:02 pm »
 I can get just as excited about an Oval on "balloon tyres" with a double carbed 1200 as about a yellowish convertible with a type 1 turbo engine...
 It depends very much of the car that carries the engine... It's all in the combo..
 For a modern looker of there days a 1641+ is a minimum I think...
 About type 4's:
 I personally don't have any problems with a type 4, as long as it's made to look like a type one.
 A DTM shroud on a type 1 looks more wrong to me than a proper T4/Type-1 conversion...
  "The Full-Throttle Cruisers"
Eddie DVK
« Reply #28 on: March 13, 2007, 23:38:36 pm »
SOB/DBR:
Quote
Guess I am out of the leuge then....I have a type 4 motor....It runs well....It has been alive since 1991 in upgraded forms........It has been  fetured in the mags as a cal-look car a few times..........It runs low 12's and no fockin trailer around it.........It has been street raced regularly...............It look like a type 1 and has all the concidered richt stuff like Berg linkage, MSD coil and dist..............Hey it can even run on idle for an hour and not overheat...............So
excatly,
Why are so many people against a typ 4 engine, it s a strong reliable engine which easely makes 100hp.
And with a typ 1 shroud(cali conversion) it looks the same as a typ 1, I bet a lot of people here wouldn t even spot the difference with a typ 1 engine.
But he thats my opion.
Kind Regards Edgar
« Last Edit: March 13, 2007, 23:40:26 pm by Eddie » Logged
Regards Edgar
« Reply #29 on: March 13, 2007, 23:43:07 pm »
I think most of us started out in your situation...little money, little time.  As for minimum motor requirements, the idea of Cal-Look is SIMPLIFY...meaning clean, simple, and functional.  Avoid the louvered aluminum firewall trim, the clear distributor caps, the slip-in 88's...concentrate on building something that's reliable, leak-free, and simple to work on.  Size wise, 48IDA's have been run on 1500cc motors successfuly (it takes some doing, but it has been done).  A lot of the old DKP cars were 1700cc (69X88 machine-ins) with IDAs, an Engle 110 cam and some 40mm intake valves...ran damn good, too.  Most importantly, build it the way YOU want it...your the one who's going to be driving it, right?
Pages: [1] 2 Print
