September 22, 2026, 09:51:14 am
turbo t1 engine question!
Topic: turbo t1 engine question! (Read 7462 times)
tezer
August 08, 2010, 21:36:16 pm »
hi I'm building a turbo t1 engine
it have a 78 mm demello crank and 94 mm cylinders
the case have 8 mm bolts,but i have read that you need case savers whit 94 cylinders?
don't know if this is true or not!
and I'm also thinking what type of connecting rods that is best!
stock whit arp bolts?or something different!sorry about my bad English
Fasterbrit
Re: turbo t1 engine question!
August 09, 2010, 09:29:03 am »
An 8mm stud case already has case savers
OFF#23 OUTLAW FLAT FOUR
www.outlawflatfour.com
www.air-kraft.com
www.marcomansiperformance.com
tezer
August 09, 2010, 19:49:35 pm »
Are you sure?
this is how my case looks like!can't Se Anny case savers!
karpis
August 11, 2010, 07:00:04 am »
No they dont,mine didnt have.. i should recomend casesavers to 94mm
tezer
August 11, 2010, 14:50:56 pm »
ok thanks!
Carsten
August 19, 2010, 11:31:35 am »
Wouldn`t it be better to go M10 with a turbo engine ? Because of the boost ?!
Carsten
1969 IRS bug
yvre
Der Autobahn Scrapers
September 01, 2010, 00:15:33 am »
I'd like to know too. I just re-read Kawell's turbo 1915cc build in an old Hot VW's and he was using 10mm bolts too.
tezer
May 01, 2011, 21:02:48 pm »
yep its best to go whit 10 mm studs
or somthing stronger then this old 30 +++ yers stud i have!
realy bad my motor now,head/sylinder blowby alle the time!
