October 05, 2026, 10:07:07 am
Chakalives
coil and MSD compatability?
Topic: coil and MSD compatability? (Read 4591 times)
August 09, 2010, 23:45:13 pm »
Does anyone know if Bosch number 0221122001 (or Mercedes 0001582803) will work with MSD 6A?
stealth67vw
Re: coil and MSD compatability?
August 10, 2010, 00:11:41 am »
A couple years my Blaster 2 started leaking so I put on a used stock VW/Bosch black coil with my MSD 6AL for 6 months. I figured it would only last a little while until I got another MSD coil but it "worked".
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
August 10, 2010, 00:16:57 am »
I know a Blaster doesn't work on an 010 with points!
John Rayburn
August 10, 2010, 03:11:23 am »
Quote from: Vandelet Industries on August 09, 2010, 23:45:13 pm
It will work fine, Jim.
Quote from: Zach Gomulka on August 10, 2010, 00:16:57 am
You can also run this trouble free, if you run a ballast resistor in line.
I also park at Nick's.
August 10, 2010, 03:17:19 am »
Quote from: John Rayburn on August 10, 2010, 03:11:23 am
I figured that was the issue. We had a blue coil in stock, so we swapped it in and everything was humky dory.
