September 24, 2026, 19:09:48 pm
| | |-+  Guage postioning help
Author Topic: Guage postioning help  (Read 6184 times)
poppagee
« on: August 12, 2010, 16:55:16 pm »
Just need some ideas on where to position guages in the oval.
Got a 3 3/8's autometer tacho and 2 5/8's oil temp and pressure.
Just need some ideas of positioning
Thanks guys
Damian
« Reply #1 on: August 12, 2010, 17:06:22 pm »
Do you want to cut the dash or leave it stock? Loads of room in an oval dash... Wink
Best way of doing it is to sit in the car in your normal driving position, with the steering wheel you're going to use, and just mark the dash with masking tape. Use the right steeing wheel - I changed my wheel and now cant see my tacho under the dash...
poppagee
« Reply #2 on: August 12, 2010, 17:18:53 pm »
Want to leave the dash stock defo couldnt hack away at it.
Got a std steering wheel as well.
« Reply #3 on: August 13, 2010, 01:55:17 am »
Wünderwolff
aka Dr. Jeckill
« Reply #4 on: August 13, 2010, 06:29:18 am »
What Zach said! Cool
No seriously, what Zach said!  Grin
Or if all good advice fails, I always like the option (on older cars) where you put the revcounter on a mount on the steering column. A mount not as in a wrap tie or metal band. Rather a purpose made alloy clamp with a small eye to clamp the column and a bigger hole for the autometer. I think motometer had one in the catalogue.
Wünderwaffe are Go!
bodgit
« Reply #5 on: August 13, 2010, 13:03:12 pm »
Having a roll cage is handy, here's where mine are fitted on my Oval:
Matt
LuftsickTero
« Reply #6 on: August 13, 2010, 14:07:09 pm »
No pain no gain  Cheesy
« Last Edit: August 13, 2010, 14:08:54 pm by LuftsickTero » Logged
streetvw
« Reply #7 on: August 13, 2010, 20:35:06 pm »
mounted my Tach on the rolled edge on the dash using the tube mount supplied with my tach worked great and hardly any wobble  Wink
jonathan
« Reply #8 on: August 13, 2010, 20:40:46 pm »
I'll come round tomorrow with a hole saw dude!
I can bring the mig welder to get rid of the side trim while we're at it. Tongue
I've got a set of t-bars knocking around I could bring.We could make a day of it! Grin
poppagee
« Reply #9 on: August 14, 2010, 10:27:20 am »
jeez.....
best lock the door
« Reply #10 on: August 15, 2010, 01:07:19 am »
I like the fact that the hole saw is red. It's as if it has fresh dash blood on it Grin
