September 23, 2026, 01:17:37 am
| | |-+  um...er... merged header and turbo muffler
Author Topic: um...er... merged header and turbo muffler  (Read 4338 times)
beetletom
« on: August 12, 2010, 21:27:59 pm »
fitted it onto my 1300 today, to see what it sounded like, is extremely quiet, and had no power whatsoever  Cheesy
whats the minimum sized engine it will work on? a 1600???
the muffler itself is 2 1/2" bore
not sure what size the header is
thanks
bugnut68
« Reply #1 on: August 12, 2010, 22:54:15 pm »
I would say no bigger than 1-3/8 inch diameter tubing for a 1300 engine.  Check the tube diameter at the flange going to the cylinder head to see what the internal diameter is.  If it's killing your engine's bottom end power, odds are it's too big.  Most merged headers are offered in 1-1/2, 1-5/8 and 1-3/4 inch sizes, if not bigger for all-out race engines, while the standard small-flange, swedged collector (non-merged) heater box headers typically measure 1-3/8" in dimeter on the primary tubes.
benssp
www.callookvw.com
« Reply #2 on: August 12, 2010, 23:31:35 pm »
if your running single carb, you'll get problems with tickover without heatrisers to the inlet manifold it'll probably ice up Smiley
www.vwheritage.com  My Job
YMCA
