September 22, 2026, 11:29:32 am
| |-+  For sale!
| | |-+  ***SOLD***Berg Heads, Throttle bodies and Rockers
Author Topic: ***SOLD***Berg Heads, Throttle bodies and Rockers  (Read 4142 times)
didi
« on: August 14, 2010, 19:58:59 pm »
GB870 New Cylinder Heads
Manley 43.7 intake and 37.5mm exhaust valves,  Reshaped 43cc chambers,welded above and below intake ports, ported, polished to larger gasket size and match ported to EFI manifolds. Spark plugs relocated, GB 273A spring set with titanium retainer, Berg seats, Berg's 3-angle valve job, Intake port bump is welded up. Spring seating area welded and re-machined to captivate springs. Pushrod tubes relocated for best ratio rocker arm clearance and large enough to accept the VW 025-109-335 pushrod tube and VW 070-109-345 seal. BoreSize for 90.5/92mm cylinderset (head Diameter 98mm), built by Clyde Berg
1390EUR
GB590FI-53P New Manifold Throttle Bodies 53mm with billet and polished Velocity Stacks, Injector Braket, Match ported to the GB870 Heads
890EUR
GB 411-140  Used Forged 1.40:1 Rocker set with all shims, new GB 369-8 Lash caps, new long GB 409A-4 HD Mounting studs with and HD 8x15mm muts
290EUR
all parts together 2390EUR
more pictures available, please ask if you are interested, shipping worldwide possible / i can bring the parts to DDD8
« Last Edit: August 15, 2010, 18:33:45 pm by didi » Logged
Didi - Aircooled VW
http://didivw.blogspot.com/
didi
« Reply #1 on: August 14, 2010, 20:00:38 pm »
more pics
Didi - Aircooled VW
didi
« Reply #2 on: August 15, 2010, 18:34:12 pm »
All parts are sold!
Thanks for all your interest.
Didi - Aircooled VW
