October 13, 2026, 00:48:11 am
***SOLD***Berg Crank, Carillo Rods, Cam, Bearings, ...
Topic: ***SOLD***Berg Crank, Carillo Rods, Cam, Bearings, ... (Read 4274 times)
didi
August 14, 2010, 20:29:21 pm »
Berg 86mm Crankshaft
Berg T4 Center Main Bearing for Std T1 case, new
Mahle Mainbearing set with center groove modification by AJ Sims, all Std, new
Berg matched 200mm Flywheel, resurfaced
Berg Equalizer Pulley
Berg Dual Friction Disc, new
Stage 2 Pressure Plate, new
Carrillo 5.5" Rods with Porsche journal, refreshed, installed with used SPS rod bolts, and with a set new ARP CustomAge625+ rod bolts
Kolbenschmidt Rod bearings "trimetal", new
Straight Cut Cam Gear set with all washer, new
Berg GB315 CAM (FK87) and clearance for 86mm Berg Cranks / Carrillo Rods, new
Berg Double Thrust CAM Bearing set, new
and all other small parts on the picutres
Crank, Flywheel, Pressure plate and pulley are professionaly balanced, first each part alone, then all parts together.
all for only 2690EUR
more pictures available, please ask if you are interested, shipping worldwide possible / i can bring the parts to DDD8
Last Edit: August 15, 2010, 18:29:17 pm by didi
Didi - Aircooled VW
http://didivw.blogspot.com/
didi
Re: Berg Crank, Carillo Rods, Cam, Bearings, ...
August 14, 2010, 20:31:35 pm »
more pics
Didi - Aircooled VW
didi
August 15, 2010, 16:08:37 pm »
Yes, the crank is also in perfect condition, rod an main diameters are checked by engine builder befor it was balanced. all parts are ready to use
tanks for all your interest
didi
Didi - Aircooled VW
didi
Re: ***SOLD***Berg Crank, Carillo Rods, Cam, Bearings, ...
August 15, 2010, 18:30:08 pm »
All parts are sold!
Thanks for all your interest.
Didi - Aircooled VW
