November 02, 2026, 19:30:41 pm
| | |-+  De-Seaming Front Quarter Panels
Author Topic: De-Seaming Front Quarter Panels  (Read 7263 times)
« on: August 17, 2010, 00:14:18 am »
Is this as easy as cutting/grinding off the metal lip, welding it up, and grinding the weld back? Is there reinforcement needed? The side of the car look sooooo much cleaner without it. Thanks!
Dave Rosique
nobodyouno
« Reply #1 on: August 17, 2010, 04:33:27 am »
Sorry Zach, I could not find this mod in my copy of "The Cal-Look Rule Book"
Better luck next time Cheesy
« Reply #2 on: August 17, 2010, 04:43:11 am »
I beg to differ!!
Gabbard, you got anything??
Andy
« Reply #3 on: August 17, 2010, 08:21:30 am »
I did this on my car, I simply cut a section of the seam away, an inch or two at a time, welded up that section and gradually worked all the way down the seam. I then used lead over the top, instead of filler/bondo as I suspect this would crack with the stress from the doors. Three years of use and no cracks so far so I think this method is fine.
« Reply #4 on: August 17, 2010, 14:13:48 pm »
I cut about a 1/4 inch on each side of seam and welded a strip back in place and if done carefully can be metalfinished with no filler at all, My concept 67 has pictures of it finished on here
« Reply #5 on: August 17, 2010, 18:20:07 pm »
That is the exact route I was planning on taking...
I saw the pictures on your other post, but do you have any pictures of the process? The way you're describing it (the way I'm seeing it), it seems like a lot of structural intergrity would be lost.
jick
« Reply #6 on: August 17, 2010, 18:31:34 pm »
did you TIG that Danny?  what d'you think about doing it with a MIG? would the other method Andy mentioned be better for somebody less talented than yourself?
cheers Jick
« Reply #7 on: August 17, 2010, 19:56:36 pm »
this one is on my "to do" list too  Grin
« Reply #8 on: August 17, 2010, 20:08:22 pm »
did you TIG that Danny?  what d'you think about doing it with a MIG? would the other method Andy mentioned be better for somebody less talented than yourself, say Zach?
cheers Jick
Fixed it for you Wink Grin
jick
« Reply #9 on: August 18, 2010, 00:14:23 am »
did you TIG that Danny?  what d'you think about doing it with a MIG? would the other method Andy mentioned be better for somebody less talented than yourself like...(insert any name here)
cheers Jick
and so it goes on..,,
