October 13, 2026, 07:18:10 am
| | |-+  Regulator for 48 IDA Webers...Professional Products
Author Topic: Regulator for 48 IDA Webers...Professional Products  (Read 14537 times)
BeetleJuice
« on: August 21, 2010, 23:15:34 pm »
What is a good quality reg for 48's? I see a number of people running the Holley.
I've recently seen these regulators and was wondering if anyone has used them? They do look good. Any Experiences?
Specs as per Website: http://www.professional-products.com/fuelregulators.php
2-Port Regulator 2 to 4 PSI
10662 Blue Anodize
10663 Aluminum Finish
This is the ultimate in a compact, affordable fuel pressure regulator. Features billet aluminum construction, stainless mounting bracket, and stainless hardware. Compare to a Holley® 12-804 or similar regulator. Suitable for engines up to 450 hp. Use two units for higher hp applications with dual carburetors.
(1) 3/8-NPT Inlet Port (2) 3/8-NPT Outlet Ports .220 (7/16") Restriction
Craig
« Last Edit: August 24, 2010, 00:58:24 am by BeetleJuice » Logged
« Reply #1 on: August 22, 2010, 00:21:41 am »
Hi Craig, I'm using the old cast reg. without no problems, seems to hold the pressure at 3 1/2 lb., but now seeing the new stuff, WOW looks nice. time to upgrade. I would say the new ones should be better. My 2 cents.
Ted
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #2 on: August 22, 2010, 06:38:06 am »
  4.5 to 9 psi   too much pressure.   I didn't read real carefully but it looks like the lowest they have  was 4.5 psi.
« Reply #3 on: August 22, 2010, 20:37:53 pm »
Jason, just below the 4 1/2 to 9 is the 2 to 4lb reg., looks good!
Ted
BeetleJuice
« Reply #4 on: August 23, 2010, 11:38:45 am »
Hi Ted
Ordered mine today going on your 2 cents. Grin
I have it here by the end of the week. I'll post some pics.
Craig
Jason Foster
« Reply #5 on: August 23, 2010, 14:41:35 pm »
Gotcha Ted  like I said I didn't read real carefully. looks nice
« Reply #6 on: August 23, 2010, 17:09:44 pm »
Hey Jason, Ya! looks real nice, Beetlejuice, I think I'm to order one also. Gotta be good. Had no problems with my cast one. Will soon see. Ya post some pics when you install it and a report on how it works also.
Ted
mick
« Reply #7 on: August 23, 2010, 18:15:51 pm »
hi all bit of advice required regarding 48 idas ! would you use a regulator if your using CBs 3.1/2 PSI (CARTER) fuel pump ?
mick
« Reply #8 on: August 23, 2010, 20:07:32 pm »
I would say no, but maybe call CB to make sure.
Ted
BeetleJuice
« Reply #9 on: August 25, 2010, 11:36:04 am »
HI Ted
Got my regulator & pump today! Grin
Attached is a couple of pics. Cool
BeetleJuice
71CALRIPPER
« Reply #10 on: August 25, 2010, 12:09:46 pm »
How much it set you back dude?
« Reply #11 on: August 25, 2010, 16:36:27 pm »
USD 49.99 at Summit
Zündfunke
« Reply #12 on: August 25, 2010, 21:22:50 pm »
How high is the repuired fuel pressure for the 48 IDAs? Or what is the max. they can handle?
BURN OUT Syndrom
« Reply #13 on: August 25, 2010, 21:49:08 pm »
I believe with a Weber needle and seat is 3 1/2lb., with the after market glass needle and seat like JC sell, you can go higher. Maybe call Jack @ JC Ent.
Ted
« Reply #14 on: August 25, 2010, 22:16:19 pm »
HI Ted
BeetleJuice
Hey BeetleJuice, that is real nice. For awhile there I thoght it was a new design from Holly, but still looks cool, compact, I still may order it. as long as it holds 3 1/2lb, which I think it will. I checked out the web-site, the company has some nice reg. should work pretty good! What does the bracket look like?
Ted
BeetleJuice
« Reply #15 on: August 26, 2010, 00:59:53 am »
Here's some pics of the bracket.
« Reply #16 on: August 26, 2010, 01:12:35 am »
That is, a really nice set-up, billet with stainless. Post some pics of install when you get it on. Thanks BeetleJuice.
Ted
« Reply #17 on: August 26, 2010, 19:57:08 pm »
Ted
You can go up to 5 lb. with the steel or glas ball needle and seat
« Reply #18 on: August 26, 2010, 21:34:07 pm »
There ya go, thank you Udo for the info.
Zündfunke
« Reply #19 on: August 27, 2010, 06:33:21 am »
Thanks for the info!
BURN OUT Syndrom
« Reply #20 on: August 28, 2010, 05:05:33 am »
I`ve used the old style Holley with great results for years. Why change? The new one looks to modern/race car to me.
« Reply #21 on: August 28, 2010, 08:09:00 am »
That maybe true, but gotta admit, that new one still looks good and compact, a little shorter. Nothing wrong with a little new school with old school, I say.  Grin Like MSD vs Bosch 010.  Wink
Ted
« Reply #22 on: August 28, 2010, 15:56:23 pm »
I had a lot of problems with the old holley regulator.I had to adjust it every weekend and now i want to use a magna fuel that looks much better .
Old things must be changed some times ... Wink
« Last Edit: August 29, 2010, 08:47:41 am by Udo » Logged
BeetleJuice
« Reply #23 on: August 28, 2010, 22:01:34 pm »
I had a lot of problems with the old holley regulator.I had to adjust it every weekend and now i want to use a magna flow that looks much better .
THis is why I went this way.....It seems there is too many issues creeping in with the holley reg. Besides, my Bug is not really a Cal-Looker so no rules apply! Grin
I also think they look neat.
BeetleJuice
The Burnout King
« Reply #24 on: August 28, 2010, 22:49:21 pm »
BeetleJuice
Keep an eye on that regulator as well.... There pretty much the same as a holley, just billet.
go BIG or go HOME
www.theburnoutking.com
« Reply #25 on: August 29, 2010, 00:09:35 am »
Some good info on regulators:
http://www.centuryperformance.com/mallory-fuel-pressure-regulators-selection-spg-81.html
« Reply #26 on: August 29, 2010, 08:49:11 am »
BeetleJuice
 Huh
So which ones work well ??
RhoadsVW
« Reply #27 on: August 29, 2010, 09:42:45 am »
I run the Carter fuel pumps with Mallory regulators.  I ran the Holley regulators for years but started having trouble with leaking and not having stable pressure. Switched to Mallory in both my cars.   Dave Rhoads
Der Renwagen Fuhrers
