October 15, 2026, 00:07:45 am
| | |-+  What Gearbox to go for?
Author Topic: What Gearbox to go for?  (Read 6255 times)
Blob
« on: August 24, 2010, 21:29:11 pm »
Hello
I am looking for a new gearbox. But to find the right one, I could use some advice.
The gearbox should be for steet use.
The gearbox will have to be able to handle 250hp
It has to be with IRS
It need to have a high 4. gear, to reduce the rpmīs and noice at the motorway.
What gearing should I go for?
What about the shafts? Should I change them together with gearbox? Today it is all standard.
I could really use some advice about the brands. I have been looking at:
Rancho, KCR and Strictly foreign.
Any other brands that I should take a look at?
Any other things that I have forgotten?
Hope some of you will share some experience with me.
Jakob
Dominick Luppino
« Reply #1 on: August 24, 2010, 22:25:23 pm »
I'm very happy with Rancho, been using them for years!
« Reply #2 on: August 25, 2010, 00:28:51 am »
Bus.
glenn
« Reply #3 on: August 25, 2010, 00:39:10 am »
Go for a 5 speed and be done with it.
Quote
    Transaxle Specs: Type 1, Gene Berg 5 Speed Manual, IRS
    Builder - Gary Berg
    Case - Volkswagen "Rhino" case, heavy duty side covers
    Mounts - Gene Berg GB-642P heavy duty rear mounts and Gene Berg GB-643F front crossmember
    Gear Ratios - Close ratio 1st, 2nd, 3rd, 4th and 5th, steel shift forks, hardened keys
    1st - 3.78:1 (heavy duty)
    2nd - 2.06:1 (stock)
    3rd - 1.58:1 (welded hub)
    4th - 1.21:1 (welded hub)
    5th - 0.82:1 (welded hub)
    Rev - 3.61:1
    Differential - ZF, Limited Slip (LSD) with 4 spyder gears (11 tooth)
    Ring / Pinion - 3.875:1 ratio, 8 bolt, Gene Berg GB-660K-3875 (Klinkenberg)
    Shifter - Gene Berg GB-5710 5 speed shifter w/ old style Berg "Finger Grip" handle, new shift rod bushing
    Axles - Type 181 stub axles and C/V joints with Sway-A-Way Axles
    Misc. - heavy duty cross shaft (welded), GBE Super Duty Pinion Bearing Retainer
    Lubrication - Swepco 201 Multi-Purpose Gear Lube, 80-90W API GL-5 and MT-1 rated
Glenn
www.DasVolks.com
Long Island's Aircooled Club
« Reply #4 on: August 25, 2010, 01:29:34 am »
IRS = Bus
Blob
« Reply #5 on: August 25, 2010, 06:24:25 am »
Quote
    Builder - Gary Berg
    Rev - 3.61:1
Who have build your gearbox?
Blob
« Reply #6 on: August 25, 2010, 06:26:49 am »
IRS = Bus
What do I have to change, if I use a bus-transmission in stead of a normal bug-transmission.
I think that the bus-transmission i bigger, so will I have to modify a lot of things at the floorpan?
glenn
« Reply #7 on: August 25, 2010, 10:41:28 am »
Quote
    Builder - Gary Berg
    Rev - 3.61:1
Gary Berg
Glenn
www.DasVolks.com
« Reply #8 on: August 25, 2010, 15:11:56 pm »
IRS = Bus
Berg sells a trans mount for the bus conversion, I believe there is a small piece of the floor that needs to be modified near/at the nose cone
Blob
« Reply #9 on: August 25, 2010, 20:34:40 pm »
Okay I see.
If any of you have any experience with the companies I will like to know.
