September 24, 2026, 19:21:13 pm
4" bore OXY case
Topic: 4" bore OXY case (Read 2436 times)
Tomi
4" bore OXY case
August 26, 2010, 12:08:03 pm »
Std- size wbx case for 4" bore. T1 cranks, cams, lifters, etc. drop right in and also cooling tin and all other stuff will fit with minor modifications.
- water jackets removed
- bronze bushings for T1 lifters
- piston oil squirters from 993 turbo
- clearanced for 86mm crank with 2" rods, oil return from heads improved
- oil galleries plugged for easy cleaning
- modified for dry sump use, oil intakes at the front and rear of oil pan. Can be changed back to std oil pump if needed
- all nuts and bolts included, as well as head studs
- includes JayCee push rod tubes modified to fit the case, normal tubes won't fit
- also includes used 4" cylinders, oil seals for flywheel and pulley
Price 800 euros or best offer. Could also consider trade for stroker short block with max 94mm bore. Pics on request.
ts(a)welho.com / PM
