July 01, 2026, 03:33:47 am
chris41
Get 'R Done
Topic: Get 'R Done (Read 139876 times)
Get 'R Done
September 08, 2010, 21:41:43 pm »
After a lot of input from my mentor (Jim Ratto) and a lot of sleepless nights i'm going to build this puppy. I hope it will perform and doesn't give me any issues so i can concentrate on the other project: Kmann-T4
Like the subject title, it will be T1. Here's the specs:
Mag. Case machined and bronze lifter bushings by Steve Hollingsworth
78 CB (modified by Jakob) x 94 Berg (now Wiseco/Mahle)
Flywheel modified by Jakob (GetBackOnTrack)
Scat H-Beam rods (short) Now Bugpack.
30 MM Oil Pump
Jeff Denham Heads 40 x 37,5 (55cc'd by Udo Becker) 9.5 ish...( now 50cc) 10:5 ish)
Udo Becker 58 gramm lifters
Webcam 86B
Scat 1,4 : 1 Rockers
Manton p.rods
IDA's with 37 mm Venturies
CSP Porsche cooling system
Merged Header 39mm, with twin 2,5" Mufflers (Turbo Thomas).
Udo Becker will replace my fourth gear, so (PRO) tranny specs will be:
R & P 4.12--1st 3.80 --2cnd 2.06--3rd 1.31--4th 0.89
When i dismantle the "old" engine i will take pics of the Scat Lube-A-Lobes and post them.
Last Edit: June 17, 2011, 15:37:59 pm by Harry/FDK
wolfswest
Re: Hurry's Final T1 2165 ?
September 09, 2010, 10:24:54 am »
nice combo. good luck with it.
September 09, 2010, 17:54:04 pm »
Thanks Dem,
Monday evening i will start taking the block apart and take pics. Berg P/C's look perfect (as always).
I'm looking for a reasonable flat 3,5 quart sump. Empi ? (My CB is just a box sticking out). Anyone ?
Last Edit: September 09, 2010, 17:58:40 pm by FDK/Hurry
September 10, 2010, 08:12:25 am »
Hey Hurry,
nice combo, but hurry up
Got to see you with the car/engine again.
But how is life, are you going to DDD,
I don t know if I am going.
Got my engine running for the first time yesterday....so you hurry up.
got to say I am happy with that.
Hope to see you soon
September 10, 2010, 15:07:06 pm »
Hey Ed, for sure i will go to DDD. Early Christmas time for me....Receiving parts from Udo B. and Gunter !!!
Regards,
Harry
Last Edit: October 03, 2010, 18:29:53 pm by FDK/Hurry
September 10, 2010, 18:56:43 pm »
I think with that cam you can make run up to 10,5:1 . 98 oktan fuel is avaliable in Holland !? I can cut the heads deeper if you like
www.Udobeckertuning.de
besserwisser
September 10, 2010, 21:41:14 pm »
Are you sure you need to lift that 40mm that far with 86c and 1-1.4. Seems a bit overkill to me. You should flow the heads and see where the restriction of the valve ends and make youre choice of cam from that.
volkskris
September 10, 2010, 22:25:38 pm »
Quote from: besserwisser on September 10, 2010, 21:41:14 pm
he'll use a 86B, see his first post
September 11, 2010, 14:27:18 pm »
86b with GOOD small valve heads and that compression make a nice crisp engine. At least from what I remember — I haven't driven mine since May.
Felix/DFL
September 11, 2010, 21:51:13 pm »
Quote from: FDK/Hurry on September 08, 2010, 21:41:43 pm
After a lot of input from my mentor(JR) and a lot of sleepless nights i'm going to build this puppy. I hope it will perform and doesn't give me any issues so i can concentrate on the other project: Kmann-T4
78 CB x 94 Berg
Scat H-Beam rods
30 MM Oil Pump
JD Heads 40 x 37,5 (55cc'd by Udo Becker) 9.5 ish...
Webcam 86B
Manton p.rods
Merged Header 39mm
Homemade Quiet (Dual) muffler(s)
I would personaly change two things:
Porsche cooling against an original upright style one (for the stealth look)
39mm header against an 42mm
Have fun!
September 12, 2010, 01:05:16 am »
I´m with Udo. That cam WANTS more CR. 10,3 is my personal preference, but I´m sure even 10,5 is safe.
Ditch the Porsche fan system. It looks good, but robs power and its not up to par when you run stock style heads.
39 mm header (?) OD. or ID. I hope you mean ID. If we talk OD. you will burry some upper end power there. on the other hand it will pull like a freight train in the lower rpm.
September 12, 2010, 17:32:24 pm »
Quote from: Udo on September 10, 2010, 18:56:43 pm
Last Edit: January 03, 2011, 18:20:38 pm by Harry
September 12, 2010, 17:43:14 pm »
Quote from: Torben Alstrup on September 12, 2010, 01:05:16 am
Felix / Torben, i will take it from there (39mm ID), and can always play with a bigger header. I will go with Udo's feel about CR.
Felix, the Porsche system has always been a "Must Have" thing for me for years. I just can't resist anymore...
Thanks for all the input, i'll keep you posted.
Harry
PS, should i shim the CR under the cylinders or combine with a copper-head shim. (Under-- makes the cylinder shorter).
Last Edit: September 12, 2010, 18:10:57 pm by FDK/Hurry
September 12, 2010, 19:46:42 pm »
I would use cylinder spacer
By the way , the heads look good , as far as i can say the 86b cam is ok. 86c would be too much for the heads
September 12, 2010, 20:14:03 pm »
Thanks Udo.
Last Edit: January 05, 2011, 17:49:31 pm by Harry/FDK
September 13, 2010, 20:03:42 pm »
I like to shim (1mm) under the head to keep the cylinder in the case. But what about the squish in the head
Last Edit: September 13, 2010, 20:26:02 pm by FDK/Hurry
September 13, 2010, 20:43:43 pm »
I think in your case it is better to use copper gaskets in the heads. Your 043 castings are not that strong for 94 bore...
September 13, 2010, 21:16:43 pm »
Last Edit: January 03, 2011, 18:19:47 pm by Harry
September 28, 2010, 22:49:50 pm »
Block apart, everything smooth even the Scat-hate-a-lobes. But you can see the outward going "ring" of "stress" on the tops. Impossible to photograph. I will not use that crap again. Web perfect, no pitting.
Last Edit: October 03, 2010, 21:22:11 pm by FDK/Hurry
September 28, 2010, 22:55:20 pm »
This Topic better should be in: In Da Werks.
Last Edit: October 27, 2010, 19:20:13 pm by FDK/Hurry
October 03, 2010, 17:15:00 pm »
October 04, 2010, 18:32:03 pm »
For the time being, i'm going to keep the Pro-Tranny (with 3.80 1- 2.06-2 1.31-3 and wrong 0,82-4) and see what happens. (More CR and Cam). Too much money going into this bottomless hole.
November 14, 2010, 21:24:59 pm »
I'm thinking of: CSP Ceramic 1 5/8" Header (small flange) to CSP 1 1/2" dual stainless Mufflers (small flange).
I'd REALLY would like Udo's or Beetle Factory dual muffler setup but i can't weld stainless.
16-01-2011: Problem solved with Turbo Thomas.
Last Edit: January 16, 2011, 16:30:51 pm by Harry/FDK
November 17, 2010, 22:33:47 pm »
Anymore suggestions ?
Last Edit: January 16, 2011, 16:32:15 pm by Harry/FDK
November 17, 2010, 22:47:09 pm »
i know a guy that once said: just build the f*cking thing
DVK ~
November 19, 2010, 19:27:04 pm »
Bad pics, but you can see the outgoing stress in the casting.
Last Edit: November 19, 2010, 19:40:14 pm by FDK/Hurry
November 19, 2010, 19:35:47 pm »
Last Edit: November 19, 2010, 19:39:07 pm by FDK/Hurry
November 19, 2010, 23:17:04 pm »
Quote from: 67-indeed/DVK on November 17, 2010, 22:47:09 pm
Shut Up And Drive.
November 19, 2010, 23:32:03 pm »
King of the roads says you move to slow!
http://www.youtube.com/v/_Zko7pBeHkk
Just kidding Harry! It's fun to build an engine!
November 19, 2010, 23:32:40 pm »
Case is coming in over the next 2 weeks !!! Can't wait !!!
Last Edit: November 20, 2010, 13:03:38 pm by FDK/Hurry
