October 13, 2026, 09:14:03 am
| | |-+  Berg mid mount on a type 3 ?
Author Topic: Berg mid mount on a type 3 ?  (Read 7343 times)
Kaferdog
« on: September 12, 2010, 23:38:11 pm »
Does anyone know if a berg or anyother mid mount will work on a type 3...?
Felix/DFL
« Reply #1 on: September 13, 2010, 14:36:35 pm »
I have an JKM mid mount installed in my notch:
http://www.jkm-tuning.com/docs/pd-342603069.htm
So a berg piece will even fit.
Have fun,
Felix
Speed-Randy
« Reply #2 on: September 13, 2010, 16:35:02 pm »
You should get one of Danny's. Way nicer than the berg mount
Prowagen
« Reply #3 on: September 13, 2010, 17:42:40 pm »
You beat me to it Felix, I was going to also suggest the JKM mid mount. I cannot see why the Berg mount will not fit either.
Both of these items are available here:- http://www.prowagen.com/CHASSIS/View-all-products.html
Cheers,
Lawrence.
Ron Greiner
DKP II
« Reply #4 on: September 13, 2010, 18:35:55 pm »
it would work on a early type 3, up to 1967 with the swing axel trans because the car has
rear frame horns and 2 rear trans mounts, but the Irs type 3's don't have the frame horns
or rear transmission mounts, just a rear engine mount
Felix/DFL
« Reply #5 on: September 16, 2010, 01:44:28 am »
Now that`s a good point!
But as I know swingaxle with horns were build up to summer 69...
The stock IRS typ-3 with no frame horns are not really made for performance.
You can convert IRS to IRS with frame horns or buy them...
There are some companys as the bugbox in Weiden which sells them.
« Reply #6 on: September 16, 2010, 02:30:58 am »
Hopefully you like this, I will have about 10 finished for sale in about a week
sofaking
« Reply #7 on: September 16, 2010, 14:43:39 pm »
X2!!!!!!!
« Reply #8 on: September 16, 2010, 19:59:19 pm »
Danny, does that require welding and what will the price be?
Kaferdog
« Reply #9 on: September 16, 2010, 20:26:20 pm »
Here ya go Louis...
http://cal-look.no/lounge/index.php/topic,13404.msg202113.html#msg202113
Kaferdog
« Reply #10 on: September 16, 2010, 20:29:47 pm »
Danny ...Don't ya have pics of the welding process....I couldn't find them I thought I saw them...?...... Huh
Kaferdog
« Reply #11 on: September 16, 2010, 22:26:38 pm »
Danny I will see if my brother will go for this ...it's his car ...I wish yours was available before I installed by Berg......I love the jack stop !!! & it looks awsome...!!!
« Reply #12 on: September 16, 2010, 23:01:45 pm »
There are two 3/16 peice's that are welded to pinch weld flange on frame horns. then holes drilled through for rubber pad. I will have a few done by the week-end if you need one.
