August 13, 2026, 02:19:41 am
| |-+  For sale!
| | |-+  Mikuni ThrottleBodies(IDA Fittment)-Fuel Rail/fittings/Injectors-Cable Linkage
Author Topic: Mikuni ThrottleBodies(IDA Fittment)-Fuel Rail/fittings/Injectors-Cable Linkage  (Read 8912 times)
Adele AW
« on: September 14, 2010, 22:38:09 pm »
We are selling our Mikuni throttle bodies, fuel rails and fittings and cable linkage.
These were custom designed by Marco Mansi, the throttle bodies are a single Mikuni body joined up to a second one making a pair with a custom linkage. The bodies are set up with custom IDA base plates as the whole setup was designed to look like IDA's and also fit IDA manifolds. On the cable linkage, the main part of this sits on top of the engine case as we had no cooling, it controls the cables which attach to both accelerator ramps on the bodies. Throttle body port size is 51 at the top and tapers down to 48 at the bottom.
The fuel rails come with -6 fittings and there are four 440cc Injectors. Also included is the throttle position sensor, and 4 polished one off stacks.
These are real one off's but using commonly available parts Smiley
Price is £850 and we can ship worldwide Smiley
« Last Edit: October 01, 2010, 15:56:52 pm by Adele AW » Logged
O/FF 621
« Reply #1 on: September 15, 2010, 16:00:05 pm »
You forgot to say that they look the bollocks! I think they're ace! Wink
Adele AW
« Reply #2 on: September 19, 2010, 10:00:39 am »
Cheers Neil Smiley
O/FF 621
Adele AW
« Reply #3 on: September 27, 2010, 16:20:19 pm »
Up they go, need to sell them Smiley
O/FF 621
Adele AW
« Reply #4 on: October 01, 2010, 15:57:14 pm »
Price changed to 850 GBP
O/FF 621
SteveW
« Reply #5 on: October 10, 2010, 22:09:38 pm »
Can take to Slough...  Smiley
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
m.m.p
« Reply #6 on: October 23, 2010, 22:01:52 pm »
some info Smiley  they are 48mm at the bottom, 55mm at the top of the throttle body , 65mm at the top of the trumpet, have a 52mm throttle plate, the system has a continious taper from top to bottom, this increases air speed to the motor = more power Smiley there is anough fuel injector for over 300hp, this combo made over 20hp more than 51.5mm IDA's on the SAME N/A motor!!!!!! and there 1/3 lighter that IDA's
a steal at £850
Smiley
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
SteveW
« Reply #7 on: October 23, 2010, 22:14:06 pm »
Thanks Marco Smiley These need to sell so we can continue with our rebuild!
Steve
1970 Stock Beetle.
SteveW
« Reply #8 on: November 02, 2010, 18:33:27 pm »
Up Smiley
Steve
1970 Stock Beetle.
Adele AW
« Reply #9 on: November 02, 2010, 21:36:48 pm »
Sale Pending....  Grin
O/FF 621
SteveW
« Reply #10 on: November 06, 2010, 22:56:21 pm »
Sold! Smiley
Steve
1970 Stock Beetle.
