October 12, 2026, 21:59:39 pm
| | |-+  Portwork from Hell
Author Topic: Portwork from Hell  (Read 45342 times)
n2o
« on: March 16, 2007, 19:19:22 pm »
Here is a picture of the new heads to my cadron equipped 1680ccm daily driver
9.88 @ 134.25 mph
Roman
« Reply #1 on: March 16, 2007, 19:23:21 pm »
Cool, I never knew that the 1680:s had a 10 stud head pattern!  Grin
n2o
« Reply #2 on: March 17, 2007, 11:47:00 am »
The main focus of porting the heads, was to remove weight. The heads are now 1 kilo lighter, and I think that will improve my ET Grin
9.88 @ 134.25 mph
« Reply #3 on: March 17, 2007, 11:55:36 am »
Are you going to run Kadrons on such huge intakes? I reckon they'll drown in there.
Did you matchport those manifolds already?
n2o
« Reply #4 on: March 17, 2007, 13:58:17 pm »
Kadrons was kind of a joke. The heads will be on top of my new 4" ARPM dry-sump case, and they will eat a lot of racefuel and nitrous.
Take Care
9.88 @ 134.25 mph
« Reply #5 on: March 17, 2007, 19:37:43 pm »
You could Quad-drone it Wink
« Reply #6 on: March 18, 2007, 15:38:57 pm »
 Grin
« Reply #7 on: March 18, 2007, 19:27:00 pm »
I might use Kadrons too  Wink
Thomas 356
« Reply #8 on: March 18, 2007, 22:07:04 pm »
Look´s wild
can waith to see it in action
is this the carbs your are making to you engine Wink N2O
and old pic 28 / pic 50 *ggg*
Thomas 356
Menber Of  Boulevard Cruiser´s
Driver of the Nasty Gray (Back In Fridolin style)
www.thenastygray.blogspot.com
« Reply #9 on: March 19, 2007, 22:28:08 pm »
I wouldn t laugh about kadrons if i where you...
you ever seen this page
http://www.lowbugget.com/main_page.html
Kind Regards Edgar
ugly duckling
« Reply #10 on: April 06, 2007, 02:28:38 am »
nice job n20 i like the way you kept the intake guide boss intaked you did these heads?. i love the AF heads. ive had great sucsess with them. they make great 250hp 91oct 9.8.1 street heads. my next set will be when i get time 55x40 pump 91oct 108mm bore type 1 street engine hopefuly pushing over  the 300hp NA envelope.  good luck to ya. again your heads look great!!.  U D
n2o
« Reply #11 on: April 07, 2007, 14:33:28 pm »
These heads have 50x40 valves and flows 262cfm@16mm lift (25" of water). I am aiming for 290-300 without nitrous
9.88 @ 134.25 mph
ugly duckling
« Reply #12 on: April 08, 2007, 07:45:54 am »
those are good numbers i notice the ID of your intake seat you have maxed out for the 50mm valve at what lift in inches did it flow the 262cfm. what was your at 3/4/500 lift cfm just curious. and you did flow with a int valve in it right?   would like to compare.   U D
« Last Edit: April 08, 2007, 07:52:42 am by ugly duckling » Logged
n2o
« Reply #13 on: April 11, 2007, 08:01:10 am »
They are messured in mm, but if I calculate to inches it is something like this:
137,2cfm@0,236"
174,3cfm@0,314"
205,2cfm@0,393"
223,5cfm@0,474"
247,2cfm@0,550"
262,0cfm@0,629"
270,9cfm@0,700"
Roar
9.88 @ 134.25 mph
ugly duckling
« Reply #14 on: April 12, 2007, 07:08:23 am »
hello n20 hear are my flow figures remeber these are street heads with 65cc chambers.200lift 123cfm.  300lift 169cfm. 400lift 203cfm. 500lift 228cfm. 600lift 241cfm. 700lift 250cfm. my lift at the valve is 6.60 with fk44 and 1.61 rockers.  52x38 stainless 7mm stems. my intake size entering into head is 1.650 tall 1.725 wide a relitivle small sq compared to others. my ex ports are 1.400 small.  heads flowed at 700 lift with int valves installed.    thanks for your responce.  U D.
« Last Edit: April 13, 2007, 02:16:34 am by ugly duckling » Logged
n2o
« Reply #15 on: April 12, 2007, 07:20:12 am »
Have you moved the intake over to center of the head?
9.88 @ 134.25 mph
ugly duckling
« Reply #16 on: April 13, 2007, 02:23:33 am »
it is in stock AF location. its a 103 bore.  UD.
n2o
« Reply #17 on: April 13, 2007, 07:14:24 am »
When we did my heads, we learned that a 52mm intake was to close to the cylinderwall (std AF location of valves), on a 101,6mm bore, the get the most out of it. That was the reason for using 50mm intake. When the intake is to close, you may hurt the flow and only end up with a heavier valve?
9.88 @ 134.25 mph
ugly duckling
« Reply #18 on: April 14, 2007, 02:18:14 am »
thats why i like the 7mm stems my 52mm intakes are the same wight ifnot lighter than 50mm 8mm stainless. i use the manley blankes so the margin is alot thiner and lighter than standerd flat top type 4 intake stainless valve. i use the tit super 7 keepers and the tit ret k800 installed hight 1.800. wich for a stainles valve train is light enoghf for what  im trying to achieve with my combo.absolutly no valve float present.  pure street torque from 2800/ 5800.  my engine is a 90x103 aunist to god street engine. no race engine here i could make it one very easly but why what would that prove absoluty nothing. i do know that i can drive my car to the trak pull my nessary stuff out like tools and jack leave all the seats. car wight is 2016lb with driver. in the 1/8th it has run a best of 7.56 at 91 and some change wich calculates out to 1/4 11.79 at 114.66mph. that was with 6in firestones. and a best time of 1/8 7.82 at 88mph wich calculates to a 12.20 at 110mph with wallmart street radials. and the greatest joy is i can load all my stuff back in my car and drive it home. the only time i ever towed my car wich was only once was at famosa it was very hot that day about 115 in the shade my car still ran 12.44 at 109 with the crapy radials. all the rest of the time i drove the car there. dont get me wrong i like race cars ive had plenty of them. but when you can take a street car NA and i mean a true street car pump gas material street car and not a light wight potato chip . and go out and run times that some light wight  race cars cant even  run then that i feel is a true acheivment in the ACVW world. its just going to get better and better. i will run a race car again some day  but i am having to much fun with the street car stuff.right now. eghonf rambeling. good luck with your ACVW project NTO. would like to here how it runs. go givem hell dude.  Wink   UD.  o ya i did tow it to vegas once but when i got there we drove a round trip of 60 miles up in the moutines to prove the street car thing. REAL STREET VERY COOL. so thats twice i towed it just tought i would set the record striat. see ya.  UD.
« Last Edit: April 14, 2007, 04:27:46 am by ugly duckling » Logged
Alan Uyeno
« Reply #19 on: April 14, 2007, 06:29:52 am »
UD,
You've got one fast street car!!!
Roman
« Reply #20 on: April 14, 2007, 11:01:06 am »
Aha! UD=Jeff Denham!
I am also building a big type 1 for the street but I limited it to 4" bore and 86 mm stroke. Like your car it is an unrestored, more or less stock bug.
The intake valves will be 50 or 51 mm Del West Ti 7 mm stems with Ti keepers and Ti retainers. If Nascar can run full throttle for 500 miles I am sure I can run one summer without any problems, even on the street. The new LS7 Corvette has Ti valves from factory, so why can't I?
Frank LUX
Back...Soon...hopefully!!!
« Reply #21 on: April 14, 2007, 12:18:45 pm »
How's your Fiat 600 doing UD. Wink Grin Grin Grin
Frank
Alan Uyeno
« Reply #22 on: April 14, 2007, 19:20:55 pm »
Huh, Denham in stealth mode  Cool
Roman, Ti valves are iffy on the street IMO unless your using Berillium valve seats.
My 2332 shortblock has been together for 2yrs. 1 year I had my SE heads with stainless valves (manton/cb chevy springs) . My valve lash was extremely consistant every time I checked. The following year I put my othe set of SE heads with CB performance Ti valves. Every 2 weeks I would check my valve lash (chromoly pushrods w/ zero lash) my intake valves would get tight all the time and my exhausts would move a tad. The next two weeks the valves would move again, again, again and again. I haven't pulled those heads apart yet but I'm just anticiapting some serious tulip. I'm running my stainless setup once again for my street car.
ugly duckling
« Reply #23 on: April 15, 2007, 05:44:00 am »
jeff denham whos that never heard of the caricter.   UD.
« Reply #24 on: April 15, 2007, 07:50:30 am »
That's good... you probably wouldn't like him  Grin
Roman
« Reply #25 on: April 15, 2007, 09:38:10 am »
I bought 8 brand new Ti valves from E-bay for $150 so it is a rather cheap test. If it doesn't work I'll just change.
n2o
« Reply #26 on: April 15, 2007, 19:54:09 pm »
Why did you go for 52mm intake?
n2o
9.88 @ 134.25 mph
Alan Uyeno
« Reply #27 on: April 15, 2007, 20:48:46 pm »
That is cheap.
You'll find most guys running stainless hardened valve seats are getting 1000 km's on a ti valve setup for the street. Berillium is the way to go but alot of headshops dont feel like getting fatally ill by breathing in the toxic material.
ugly duckling
« Reply #28 on: April 16, 2007, 02:23:09 am »
yea your probibly right rick i will make darn sure i stear clear of that guy. nto. why did i go with 52mm valves to me it matches my bore size better ive still have plenty of room between intake and cly wall and i use a thik int valve seat so when i cut the 60deg angle for the valve job it gives it the major funel afect airspeed/ torqe. thats why the real big flow figures arnt there. but like i said before its a street car. i wasent seaching for the big #s. i have ported numeroes sets of auto craft heads (drag race stuff) that have flowed well over the 300 cfm mark huge ports comparied to my wimpy AF intake ports but thats what the custumor wanted big cfm  Roll Eyes its not all in the big numbers. you can always improve a head but its alot harder to put material back. i have numeros sets of these heads so the next set will be better if i feel like it.  UD.
n2o
« Reply #29 on: April 16, 2007, 07:29:49 am »
Thanks, so if I understand this correctly, the main reason to go for that size inlet, is to have a long lasting seat for the street. 60 deg angle, is that for the seating of the valve, or is this a part of a 3 angle valve job. On my heads, we are using 45 deg angle for seating, and the rest is cut like a radius.
...and big cfm dosen't hurt if you can maintain the airspeed at the rpm you are aiming for   Wink
9.88 @ 134.25 mph
