October 13, 2026, 22:34:48 pm
Wanted
VDO Jet series speedo & spares
Topic: VDO Jet series speedo & spares (Read 9286 times)
Black Sheep
less is more
September 23, 2010, 19:30:15 pm »
I need a little help here guy's , Ive managed to track down a few Jet series gauges for my car
heres a quick pic of another set
But I need a speedo
has anyone got one or any leads
I also could do with a new tacho glass
As this one had a little accident
think i may try a watch smiths ?
Any help please would be very greatful , as I just drew a blank googling
glenn
Last Edit: September 23, 2010, 19:36:38 pm by Black Sheep
13.03 @ 98mph
Re: VDO Jet series speedo & spares
September 23, 2010, 20:06:38 pm »
Why not have a new glass cuted ? You can try to ask a glazier or a clockmaker.
Black Sheep
less is more
September 23, 2010, 21:04:32 pm »
Quote from: Nico86 on September 23, 2010, 20:06:38 pm
I'm planning on having a new glass cut for , which is why i need to find a watch smith or clock maker Nico .
But i still need a speedo too as I don't have one
Last Edit: September 23, 2010, 21:22:50 pm by Black Sheep
13.03 @ 98mph
Rocket Ron
It's old school for a reason
September 23, 2010, 21:18:41 pm »
a glazier would do that for you no problem , its not a big deal , i worked at a window co when I left school most have a pillar drill with hole cutter and plenty of water
13.12 @ 101.84
Grooving out on life
wolfswest
September 24, 2010, 08:47:31 am »
I had exactly the same problem with my tacho. A glazier can do the job for you, no problem. make sure you don't make the hole in the middle too big... Mine was and I glued the needle at the point I wanted it to be, so I can't adjust it anymore...
Aww, you got a cylinder head temp also, I'm jealous!!!!!
Larry S
September 25, 2010, 01:22:15 am »
I have a VDO Jet cockpit tach that is cup mounted vs dash mounted. I am sure the glass is the same. It was is the Radical Rod car when my brother bought the car as a street car. It worked when we pulled it out and put in a Autometer back when we were pups, if you end up needing one let me know and maybe we can make a deal. It has been stored in a dresser drawer forever.
Thanks,
Larry
September 25, 2010, 12:17:02 pm »
Good Choice of guages dude - It took me a while but I have all 10 gauges
(inc 2 cylinder head temps!)
The speedo's and tacho's come up on ebay quite often, its the others you will have trouble finding - its worth checking under "Bradley GT" kit cars as they had them fitted as stock
see what I've got here:
http://cal-look.no/lounge/index.php/topic,8725.0.html
Larry S
October 02, 2010, 12:50:16 pm »
Here is the Jet Cockpit tach I have, it is cup mounted and was mounted to the top of the dash of a 67 bug, many years before monster tachs arrived.....Might be interested in selling.
Larry
October 02, 2010, 15:38:31 pm »
Cool pod dude, you got the 8000rpm one like me most are only 6000rpm
Larry S
October 03, 2010, 00:06:39 am »
Thanks, I always liked the jet cockpit gauges. I found Autometer makes a tach now that has a chrome case and short sweep like the old ones and has a retro Autometer logo in it. I bought one this spring and mounted in my 58. It looks like an old one, I like it a lot.
Larry
