September 24, 2026, 19:53:30 pm
| |-+  For sale!
| | |-+  2332 strip engine for sale!
Author Topic: 2332 strip engine for sale!  (Read 2717 times)
roland
lates are the new splits...
« on: September 28, 2010, 13:55:32 pm »
Shrek is selling the 2332 engine that he had in his oval for the last 2 seasons...
Specs:
82X94
Alu high roof case with shuffle pin
CB PERFORMANCE "Comp Eliminator" heads Ported & polished by Head's Up (Roger Crawford)
DPR wedgemated crank & matching flywheel
Engle FK89 cam & SCAT "Lobe Lube" lifters
SCAT H Beam 5.5 rods
AA RACING cylinders & pistons & TOTAL SEAL rings
30mm oil pump & Full Flow BERG
KENNEDY Stage 2 clutch
Chevy K-MOTION valve springs, 1,5 PAUTER rockers & BERG pushrods
Carbs IDA 51.5 JAYCEE with BERG stacks
JAYCEE carb linkage, Block Off plate and oil fill..
Custom made breather box
MSD distributor with 6AL and blaster 2 coil
Exhaust A-1 1 7/8 black ceramic 2 1/2' flange with a 3' magnaflow sliencer (not the one on the pictures)
The engine has been taken apart and controlled this winter, it had less than 10 passes on it since...
Shrek managed a best ET of 11,6 with the car, weighting 930kg with driver.
The engine is running E-85 right now but can be converted to regular gas. It can also be converted to a street/strip monster with tinware and a few extra parts Smiley
Asking price: 12000€
couple of pics:
« Last Edit: September 28, 2010, 13:57:23 pm by roland (DAS) » Logged
« Reply #1 on: September 28, 2010, 14:35:21 pm »
Fantastic Car and Motor
Admired it at Avon Park this year...
I would be interested in purchasing the breather box if he's prepared to seperate?
Lee
