October 13, 2026, 10:40:11 am
| | |-+  Setting up a spool
Author Topic: Setting up a spool  (Read 16707 times)
« on: March 17, 2007, 22:57:40 pm »
Need some advice guys, Jick is trying to set up his rear axles and spool.  He is in Wales no where near the internet and needs some advice.
He is going to run a spool, it has no place for circlips to retain the axles, how does he set the axle tubes up regarding play etc.
Also does anybody know the length of short axle tubes, he bought some last year and he thinks he has been given long axle tubes instead.
Mike
Roman
« Reply #1 on: March 17, 2007, 23:57:26 pm »
You don't need any circlips if you have a spool. Just put some grease on the fuclrum plates so they stay in place and put in the axle spade.
The wheel bearing keeps the axle in the right position.
« Reply #2 on: March 18, 2007, 08:45:50 am »
Cheers Roman, thats what I thought.  Do you set up the axle tube the same way as you would if you were using a dif?
Does anybody know the length of short axle tubes?
lowfastbus
WUNDERWAFFE
« Reply #3 on: March 18, 2007, 10:35:58 am »
Don't now the lengt of a short axle tube, but it's easy to see... the cast piece on the end is much shorter then on the long types...
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
« Reply #4 on: March 18, 2007, 11:23:01 am »
Do you know the difference in length?
lowfastbus
WUNDERWAFFE
« Reply #5 on: March 18, 2007, 13:10:28 pm »
Just went out to measure it, the casted endpiece measures 8,5cm on the short versions... measured from the backing plate to the end of the casted piece.  Hope you kinda understand what I mean Undecided
WUNDERWAFFE
The Knuckle Buster
« Reply #6 on: March 18, 2007, 13:35:12 pm »
Yeah I do Smiley  Thanks a lot.
jick
« Reply #7 on: March 19, 2007, 18:59:29 pm »
thanks Lids for posting, and also those who advised.....much appreciated, at least i know now for certain i have the short outeraxles....i dont have a problem setting the axles up at the gearbox end, what's confusing me can be seen in the photo's below.....
1) this shows how much (or little) axle is protruding at the bearing end.....you can see the other axle and compare how much of it is recessed, (its about 1.5")......this just doesnt look right to me at all?? it doesnt look like theres enough room for the drum......
to compare...here is a stock axle set up..(long)
maybe you can understand why i thought my outers were the long type..... but they aren't??
any idea's people??
« Last Edit: March 19, 2007, 20:08:15 pm by jick » Logged
benssp
www.callookvw.com
« Reply #8 on: March 20, 2007, 14:23:51 pm »
what's the length of your axles jick?
bugpack catalogue states
61-66 26 11/16"
67     27 13/16"
68-    28   7/16"
as far as i can remember the only difference between the 67 and 68- axles is the splined end on a 67 is slightly shorter to fit an early drum Grin
www.vwheritage.com  My Job
YMCA
« Reply #9 on: March 20, 2007, 17:47:54 pm »
61-66 26 11/16"
67     27 13/16"
68-    28   7/16"
I'll confirm Ben's memory on the difference between 67 & 68 axles.
jick
« Reply #10 on: March 20, 2007, 19:36:41 pm »
my axles are the 26 11/16"......
jick
« Reply #11 on: April 12, 2007, 15:45:52 pm »
managed to do a little more work on the car over easter..............
in case anyone's interested it turns out that my outer axles consisted of a combination of long tubes with the type 1 early short end castings....and they were actually wider each side than a normal long axle outer assembly, and the inner face where the spring plate bolts to was about 2.5" outside of where it should have been....no wonder i was confused.
fuck knows what they were meant to fit.... Roll Eyes
still...its all sorted now, had to pull some of my '64 project.
« Reply #12 on: April 13, 2007, 03:29:18 am »
67 only,cheers richie,uk
benssp
www.callookvw.com
« Reply #13 on: April 13, 2007, 10:38:28 am »
Do they use early or late bearing caps jick?
YMCA
benssp
www.callookvw.com
« Reply #14 on: April 16, 2007, 16:13:41 pm »
FYI 67 axle tubes appear to be one year only with early 311 bearing caps Grin
YMCA
« Reply #15 on: April 17, 2007, 00:01:34 am »
Aren't 66 the same?
« Reply #16 on: April 17, 2007, 04:33:03 am »
Aren't 66 the same?
'66 and earlier used short axles.
