October 13, 2026, 00:32:46 am
| | |-+  2276 questions
Pages: 1 2 [3] 4 5 6 Print
Author Topic: 2276 questions  (Read 130945 times)
« Reply #60 on: May 02, 2008, 21:13:24 pm »
Damn,
i think its the pulley then,
because i still have an original one and this takes more effort to get on...µ
think i m gonna get me a santana style then
thanks for the help!! getting a little bit closer Smiley
« Reply #61 on: May 28, 2008, 12:49:01 pm »
hello guys,
i found out with my DH that i will get a compression of 9.3 to 1
i know its on the low side for my 86 c, but do you think the motor will run that bad?
got my stacks as well Smiley
« Reply #62 on: May 28, 2008, 15:11:31 pm »
Hey guys!
another q i have about pulleys:
do they have to have a tight fit on the crank?
i know with my equaliser i can slide it over the crank with ease...
Is it a real berg pulley? or one of the black copies,I know that some of the black copies are not machined to a tight enough tolerance and are loose on the crank Roll Eyes
cheers richie,uk
« Reply #63 on: May 28, 2008, 17:17:28 pm »
no its one of the copies...
i hope i have more luck with a scat Smiley
no money for berg Smiley
« Reply #64 on: June 05, 2008, 22:34:31 pm »
worked some more on the engine today..
painted my header too..still a few coats to come
« Reply #65 on: June 10, 2008, 20:45:14 pm »
was mocking my muffler up today...
i m gonna aim it to the left to be a little different  Smiley
« Reply #66 on: June 10, 2008, 20:45:57 pm »
and one more...
« Reply #67 on: June 11, 2008, 14:13:25 pm »
mmmm "een linksdrager".
« Reply #68 on: June 11, 2008, 16:30:59 pm »
haha nicolas, you crack me up Smiley
« Reply #69 on: June 11, 2008, 17:14:59 pm »
 Wink
donder
« Reply #70 on: June 13, 2008, 18:35:52 pm »
peter, did you allready weld the nut for the O2sensor on the collector ?
ya going to bug in ?
see ya
« Reply #71 on: June 13, 2008, 22:36:17 pm »
hey Philip,
i sure did..
and i sure will SmileySmiley
« Reply #72 on: June 14, 2008, 23:53:28 pm »
did a ittle work on the fan shroud today...
cut off the snorkels and cut patches to weld in...
i am keeping the internal vanes as they were to keep it as original as possible
i read on the samba that blocking the snorkels with freeze plugs with a 1.5" hole in them mimics the original backpressure in the shroud
i removed the snorkels , so i will weld in the patches and make hole in them..
hope it will work ok  Huh Roll Eyes
SlingShot
« Reply #73 on: June 15, 2008, 03:08:43 am »
If you leave the muffler purple and your header is orange, I don't think it matters what direction you point the muffler, you will be different. Wink
BTW Glass packs kick ass, good choice Grin
Will Race For Beer !!!
« Reply #74 on: June 15, 2008, 07:21:48 am »
hehe, i m gonna paint it all orange Grin
if it doesnt work out, i will change it to white...
« Reply #75 on: July 16, 2008, 19:58:35 pm »
hey guys,
how do you intall your lash caps?
i boiled them in water Smiley but they were still a bit tight on the stem during installation..
not all caps are fully seated .. i m gonna try to use the valve spring compresser to push them on...
« Reply #76 on: July 16, 2008, 20:08:29 pm »
hey guys,
Usually they are loose and fall off easily Shocked  Which brand do you have?
cheers richie
« Reply #77 on: July 16, 2008, 21:35:47 pm »
hello,
they are cb ones that came with the rockers..
i heard that berg ones tend to be tight as well...
but it seems that my spring compresser did the trick
the caps are sitting equally high now Smiley
« Reply #78 on: July 16, 2008, 22:30:21 pm »
hey guys,
cheers richie
This happens to the Scat caps . I wish the Bergs would be avaliable again .
Looks like the CB fit correct ?
« Reply #79 on: July 16, 2008, 22:32:12 pm »
hey guys,
cheers richie
Scat,CB,Bugpack, all the same
cheer srichie
« Reply #80 on: July 17, 2008, 16:00:54 pm »
I used CB's last time around and they fit tight like Bergs. Not loosey-goosey like Scat.
stealth67vw
« Reply #81 on: July 18, 2008, 05:55:11 am »
I've got a set of CBs right now and they fit snug, butt not a press fit like the Berg's. I can pull them off with a pair of pliers. They don't require the force of two mating elephants.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
« Reply #82 on: July 21, 2008, 13:29:45 pm »
hey guys,
i checked the valvetrain geometry today,
i think all looks good ..
tell me if somethinglook s wrong please Smiley
i ll have my pushrods cut next week
« Reply #83 on: July 21, 2008, 13:36:50 pm »
Oh yeah, i forgot to say:
pics were take at half lift, so 7 mm ; adjusters line up with the pushrods , and the rocker touches the lash cap just in the middle.
wow the first thing that bolts on without headaches Smiley
about the placement of the rockers now... i know they have to be set up with an offset to make the valves spinning, but how much?
heres a pic of how they are set up now:
anyway thanks for all the help i allready got, without you, i could not have done it, and lets keep our fingers crossed that it stays together Smiley
« Reply #84 on: July 21, 2008, 20:38:59 pm »
Looks good to me Smiley
cheers richie
« Reply #85 on: July 21, 2008, 21:01:26 pm »
Richie, the offset you mean? Smiley or the rest Smiley
« Reply #86 on: July 21, 2008, 21:11:08 pm »
all,
assuming the valve locks[keepers] arent touching each other completely?then the valve will not spin anyway so you are worrying about nothing Smiley
 This is the way i understand it,someone correct me if I am wrong?
but I try to get the rocker in the middle of the lash cap for maximum contact and dont worry about anything else
cheers richie
« Reply #87 on: July 21, 2008, 21:28:42 pm »
Thanks again for the help,
now that you mention that, it makes sence that the valves can not spin
i thought i learned that at school a long time ago.. i guess not then Smiley
and i checked that the keepers dont touch each other, so thats OK as well
i ll reshim the rockers now, in order to get a full contact Wink
« Reply #88 on: July 22, 2008, 18:18:09 pm »
hey guys ,
shimmed the rockers today,
and they are now centered on the lash cap; but the inlet rockers are not shimmed at both sides;
only the side of the rocker stand is shimmed and the side of the shaft ( where the shaft becomes thicker in the middle) the rocker just rides against it...
dunno if it is a problem or not?
« Reply #89 on: July 24, 2008, 19:22:20 pm »
guys,
a question for the near future...
i want to break in my engine without cooling tins to easily check for oils leaks and so on..
i want to do some test runs on the street, so how long do you think i can drive without cooling ? Smiley
i have an oil temp gauge , but i m worrying about the heads.
thanks!
