September 22, 2026, 23:17:54 pm
| | |-+  New winter project: 1641cc Rebuild with a few little changes ;)
Author Topic: New winter project: 1641cc Rebuild with a few little changes ;)  (Read 14435 times)
« on: October 09, 2010, 00:37:32 am »
Well after the thrash to Eindhoven/DDD and another 500 odd miles of "Racing my friends" the 1641cc Manx motor is finally dying!  Cry
on the way home from work today she started to "Knock" and get very HOT  Undecided I know its been getting tied for a while now and I think the last few "Races" have just tipped it over the edge hehehehehehehe Wink
It still run's and drives fine but has NO topend power and once warm it knocks really badly under load and is using ALOT of oil,  oh yeah and there is a hint of blue smoke drifting from the breather box on idle  Cheesy
its not too much of a problem as winter is nearly upon us and i have been wanting to make a few internal changes for a while ie cam  Wink
As a few of you will remember I did alot of work on her a while back (twin carbs, header, etc) http://cal-look.no/lounge/index.php/topic,6900.0.html
Here are the current engine specs:
- AS21 case - full flow oiling
- 69mm counterweighted crank with lightened and balanced rods
- Lightened and balanced and 8 dowelled 200mm flywheel
- 87mm barrells and pistons
- Stock 311 Con Rods (lightened/balanced)
- CR 9.01:1
- Engle 100 cam
- Straight cut timing gears
- "Bolt up" rocker sharfts with Porsche style swivel feet adjusters
- VW 1.1:1 rockers
- 3/8 thick walled Ali pushrods
- Stock dual port heads 040's with stock valves (mildly ported)
- 32mm oil pump (race trim)
- deep sump
- Bosch 009 dizzy with electronic ignition kit (30degs)
- Bosch Blue coil
- 8mm silicon leads
- Custom (short/reversed) Race Trim manifolds (Type3 length)
- x2 Original Weber 40DCN14's (3 bolt type)
- 32 venturis, 130 mains, 50 idles (http://cal-look.no/lounge/index.php/topic,12779.0.html)
- DDS centre pull linkage (modified with custom swivel piece)
- Power pulley (smaller 356 diameter)
- 30hp fan housing (scat - with oil cooler out the back)
- HP1 Oil filter
- Large external oil cooler
- Braided 1/2 oil lines (with proper fittings!)
- 4 into 1 header with single glasspack muffler
So what are the plans/ideas for the rebuild:
- Engle 110 cam/new lifters
- Re-balance of crank, rods, flywheel, clutch, pistons
- slight raise in CR to nearer 10:1
- some more head work especially on the exhaust
- some chamber work, smoothing etc
- 3 angle valve job
- New valve guides
- All new bearings (cam, main, rod)
- New rings (maybe new barrels & pistons but hopefully not)
- oh and a 30mm Berg oil pump (seeing as everyone thinks my mine is too big!)
- and some tips from this handy little thread: http://cal-look.no/lounge/index.php/topic,8007.0.html
So what are your thoughts guys - let me know what you think to my ideas & plans  Smiley
Also anyone know someone who can do the guides and valve job for me Huh
« Last Edit: October 09, 2010, 00:55:25 am by monkiboy » Logged
« Reply #1 on: October 09, 2010, 08:04:22 am »
i think it might also need a line bore and crank regrind.
« Reply #2 on: October 09, 2010, 08:23:54 am »
I think you're going to have a tough time getting close to 10:1 with a 1641. I also think to the only way you're going to get a substantial, worthwhile power increase is through displacement. I just happen to know a guy with a sweet set of NPR 92's Wink
« Reply #3 on: October 09, 2010, 13:31:30 pm »
Firstly Thanks to Alex/Jesus for the PM, I will look into it dude  Smiley
Lids - I will of course be measuring the case and crank, I think the case will be ok and the crank was NEW when the motor was built so hopefully it will also be ok  Undecided Smiley
Zach - the only reason I was gonna go UP in CR  is because I will loose some material when I smooth/modify the chamber so I thought I might aswell get them flycut again afterward and aim for about 9.8:1 - I think I will be ok  Undecided Smiley
Overall I am pretty happy with this little 1641 motor and I don't want to get carried away and start build a "bigger motor" Wink
I just feel this motor needs a little refining and with a little more CR, headwork, Cam it will be AWESOME  Grin
The main thing is that Engle 100 as it really limits the Rev's (approx 5k)  Undecided Smiley
« Reply #4 on: October 09, 2010, 14:44:05 pm »
Hmm, that combo should pull past 5k. Valve float?
« Reply #5 on: October 09, 2010, 18:10:12 pm »
yep it starts to "float" at much above 5k and from what Mr Ratto said in my other threads it seems that the Engle100 is not really designed to go past 5k  Undecided Any thoughts Huh
it might not help that my guides are pretty worn  Cheesy
« Reply #6 on: October 09, 2010, 23:52:38 pm »
IMO, the hp peak will be just below 5k, but it should keep pulling beyond that. You've got a valve spring problem, but obviously your bottom end needs attention, too. Anyway, a 11O with good springs/heads will do your motor good Smiley
« Reply #7 on: October 10, 2010, 03:30:50 am »
Hmmmmm interesting - when I had the heads worked on a while back (flycut & ported) the guys added hardened collets and cromoly retainers and set all the valve spring heights/pressures BUT they did say the guides were pretty heavily worn  Undecided
I think with the heads reworked and a little more port work along with the 110 will be a awesome little combo
I am also thinking of having my exhaust Re-made (from scratch!) it is a little to smaller bore and I am not totally happy with the look of it, I have a few little ideas to refine "The Look"
I have a contact through my current company that makes "custom exhausts" and his work is pretty impressive - we had a set of Turbo manifolds made for a V8 the other week and they were very nice  Smiley
« Reply #8 on: October 10, 2010, 16:47:39 pm »
Do you know your deck height/chamber CC's?
« Reply #9 on: October 10, 2010, 18:29:38 pm »
I know the deck height is .060 or 1.5mm and as far as I remember the CC is around 42/44cc what ever works out to be 9.1:1  Smiley
« Reply #10 on: October 11, 2010, 03:16:49 am »
Even if you don't buy my 92's I think a displacement increase is the smartest direction to take. For example, 92's will raise you to 9.8:1, and the displacement will allow you to go even larger on the cam (12O) without loosing bottom end. Increasing bore will also allow the valves to be unshrouded for more flow...
« Reply #11 on: October 11, 2010, 03:50:08 am »
Hmmmmmmmm I really didn't want to start "goin bigger"  Wink
I will have a bit more of a think about things now............ I see what you mean about it being a "smart direction"
As for the 120..... what rockers do I need for that Huh Huh Huh
« Reply #12 on: October 11, 2010, 04:11:05 am »
You can use your same rockers. You don't have to go to a 120, a 110 will work just fine but it's an option Smiley
« Reply #13 on: October 11, 2010, 06:26:50 am »
i have 94 barrels and a 120 cam i need to sell Smiley
« Reply #14 on: October 12, 2010, 01:15:13 am »
why O why did you put these ideas in my head Zach  Cheesy Cheesy Cheesy
I am kinda liking the idea of a 1835cc on DCN's  Wink
Also I have been doing a little reading on Bob Hoover's Mods:
http://bobhooversblog.blogspot.com/search?updated-min=2007-05-01T00%3A00%3A00-07%3A00&updated-max=2007-06-01T00%3A00%3A00-07%3A00&max-results=10
can someone please explain the removal of the oil cooler in a little more detail  Undecided
How do you plug the case Huh and how do you plumb the external cooler afterwards Huh
« Reply #15 on: October 12, 2010, 18:03:35 pm »
Hmmm... can't say I agree with him on all points Roll Eyes
What fanshroud/oil cooler are you running now??
« Reply #16 on: October 14, 2010, 10:43:43 am »
hmmmm what don't you agree with dude - its always good to have ALL points of view.....
As for the fanhousing - I have a Scat 30hp but with the cooler "out the back" why?Huh  Smiley
« Reply #17 on: October 14, 2010, 11:14:09 am »
Drop the compression and add a turbo!
« Reply #18 on: October 18, 2010, 12:04:32 pm »
Stop it  Wink
I am already thinking about going bigger cc which I didn't really want to do but hey thats life  Cheesy
so give me your thoughts/spec's guys  Huh Huh Huh what would you do to this little buggy motor  Huh Huh Huh
oh yeah I got an engine stand from work the other day 20quid!!!! Bonus  Grin
