November 02, 2026, 19:55:36 pm
| | |-+  MSD 6al compatable with petronix and a few other problems
Author Topic: MSD 6al compatable with petronix and a few other problems  (Read 7129 times)
Stefan Rossi
« on: October 13, 2010, 22:33:00 pm »
Hi
I have a few teething problems and thort this was the best place to get experienced answers. So any help would be gratefull thankyou  Smiley
I have just brought a msd 6AL box, ss coil and RPM module selector.
As i cannot afford to buy the MSD dizzy just yet i was wondering, if i can use the msd stuff i now have with my 009 with petronix ignition in it?
think its ignitor 1, i cant remember for sure, ill check when i get back in the country this friday.
I have seen the msd 6al box used with a 009 before but im unsureas to if it had points or not  Huh
Also my engine stutters and struggles at around 4/5000/rpm, if i put my foot down it really struggles, like not enough fuel or air
engine is a 2276
fk89 cam
044 heads
48 IDA's
The IDA's have 37mm venturis, im thinking i need 40mm?
Am i right in thinking the venturis are restricting the engine by not letting in enough air at the top end of the rev range?
Also what colour wires in the back of an autometer sport comp silver rev counter, do you hav to snip to make it work with 4 cylinder?
thanks in advance
stef
« Last Edit: October 14, 2010, 13:09:20 pm by StefFreak » Logged
Aircooled Engineering. Birmingham, England
www.ace-vw.com
Check us out on FB, www.facebook.com/aircooledengineering
www.dtavw.com
'67 vert
'67 Chevelle PT106mm turbo
'66 Lincoln
dannyboy
« Reply #1 on: October 13, 2010, 22:45:46 pm »
you should be able ot get the info off autometers website? i think thats where i got a diagram im going to the lockup tomoz ill check mine but i think you cut both Undecided
8.77@156.8mph
O/FF 60
Stefan Rossi
« Reply #2 on: October 13, 2010, 23:31:40 pm »
ok thanks dude, i didnt think to check on their website, ill get on it!
just realised i didnt reply to your pm on vzi a while back, sorry dude aha
i know theres a brown one to cut i think th other one is purple maybe?
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
tonybone
« Reply #3 on: October 14, 2010, 11:41:42 am »
Dear Stef.
Sounds like yes you need to step up in venturis. 37 is restricting ur top end especially with the FK89 which is gonna wanna do lots at the top. the 37mm are probably giving you lots of torque down low, but she must be hitting a brick wall at 5000 ish.
My 2276 with FK87 is running 42mm venturis, with 200 air correctors and 160 mains and revs hard.
not sure about the MSD stuff as Ive not done this before but are gonna upgrade soon.
Hope this helps.
Tonybone
Stefan Rossi
« Reply #4 on: October 14, 2010, 13:08:39 pm »
hi tony
thankyou very much fo the info Smiley
ok so i am going to order 4 new venturis then,
wat size would you recomend? 40, 42? i dont want to much of a flat spot in low revs because i drive the car as a daily driver aswell.
thanks
stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
« Reply #5 on: October 14, 2010, 13:36:31 pm »
What valves sizes do you run, particularly inlet?
I run 40 vents on my 2276cc, FK87 and wedgeports. Drives real nice
Stefan Rossi
« Reply #6 on: October 14, 2010, 14:37:04 pm »
my valves are 42 and 37's.
I'm thinking 40's cus I don't want to lose to much low end torque?
Anybody know about the MSD/petronix dilema?
Or will I hav to put points in the 009?
Stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
« Reply #7 on: October 14, 2010, 15:04:22 pm »
try this first when using the petronix in the 009.
schematic comes from a PDF file from the MSD website, I cropped it some time ago myself. But it's all on there.
complete file
« Last Edit: October 14, 2010, 15:06:56 pm by 67-indeed/DVK » Logged
Stefan Rossi
« Reply #8 on: October 14, 2010, 15:34:32 pm »
awesome Smiley
thanks very much for that, very helpfull!
stef
www.ace-vw.com
www.dtavw.com
'67 vert
'66 Lincoln
