September 24, 2026, 10:10:21 am
| | |-+  What Issue..?
Author Topic: What Issue..?  (Read 6538 times)
Kaferdog
« on: October 18, 2010, 03:51:10 am »
Does anyone know what issue of HotVW'S is the article on long to short axle swap is in...?..... Huh
tomi g
« Reply #1 on: October 18, 2010, 19:27:31 pm »
The tech article on long-to-short conversion is in hot VW's october 2006 issue.
Tomi
Kaferdog
« Reply #2 on: October 18, 2010, 21:38:32 pm »
Thanks Tomi.....!!
tomi g
« Reply #3 on: October 18, 2010, 22:02:14 pm »
if you don't have that issue let me know and I will scan the article for you
Kaferdog
« Reply #4 on: October 18, 2010, 22:17:56 pm »
I believe I have it but will let ya know ..Many thanks !!
Kaferdog
« Reply #5 on: October 22, 2010, 09:33:26 am »
yeah ...I have the issue your talking about ,but I'm looking for the one that describes the bearing caps.. Was there another issue..?
tomi g
« Reply #6 on: October 26, 2010, 19:56:36 pm »
yes, check this one where you can read about the bearing caps: "axles, tubes, and end castings" July 2005 hotvw's
« Reply #7 on: October 26, 2010, 20:27:09 pm »
http://cal-look.no/lounge/index.php/topic,9741.0.html
Kaferdog
« Reply #8 on: October 27, 2010, 02:49:28 am »
OK.... I'm still confused on the bearing cap thing !...
So the way I understand it is you "can" use a 67 bearing cap on a short axle...?...Long axle/short spline...?...Or do you have to use a 66 and earlier bearing cap ...? if you can use both then which one is better...?.... Huh
Kaferdog
« Reply #9 on: October 27, 2010, 23:05:53 pm »
Anyone ...?...... Huh
Gary Justus
« Reply #10 on: October 27, 2010, 23:28:34 pm »
"Better" is not the right term. I'm not going to get too far into this, but, contact this guy. EASY.....
KCR Transmissions is located at 9000 Arlington Avenue, Suite #108 Riverside CA 92503
Kevin@kcrtrans.com
(951) 688-1904
