September 24, 2026, 11:26:04 am
What Issue..?
Topic: What Issue..? (Read 6547 times)
Kaferdog
What Issue..?
October 18, 2010, 03:51:10 am »
Does anyone know what issue of HotVW'S is the article on long to short axle swap is in...?.....
tomi g
Re: What Issue..?
October 18, 2010, 19:27:31 pm »
The tech article on long-to-short conversion is in hot VW's october 2006 issue.
Tomi
Kaferdog
Re: What Issue..?
October 18, 2010, 21:38:32 pm »
Thanks Tomi.....!!
tomi g
Re: What Issue..?
October 18, 2010, 22:02:14 pm »
if you don't have that issue let me know and I will scan the article for you
Kaferdog
Re: What Issue..?
October 18, 2010, 22:17:56 pm »
I believe I have it but will let ya know ..Many thanks !!
Kaferdog
Re: What Issue..?
October 22, 2010, 09:33:26 am »
yeah ...I have the issue your talking about ,but I'm looking for the one that describes the bearing caps.. Was there another issue..?
tomi g
Re: What Issue..?
October 26, 2010, 19:56:36 pm »
yes, check this one where you can read about the bearing caps: "axles, tubes, and end castings" July 2005 hotvw's
Re: What Issue..?
October 26, 2010, 20:27:09 pm »
http://cal-look.no/lounge/index.php/topic,9741.0.html
Kaferdog
Re: What Issue..?
October 27, 2010, 02:49:28 am »
OK.... I'm still confused on the bearing cap thing !...
So the way I understand it is you "can" use a 67 bearing cap on a short axle...?...Long axle/short spline...?...Or do you have to use a 66 and earlier bearing cap ...? if you can use both then which one is better...?....
Kaferdog
Re: What Issue..?
October 27, 2010, 23:05:53 pm »
Anyone ...?......
Gary Justus
Re: What Issue..?
October 27, 2010, 23:28:34 pm »
"Better" is not the right term. I'm not going to get too far into this, but, contact this guy. EASY.....
KCR Transmissions is located at 9000 Arlington Avenue, Suite #108 Riverside CA 92503
Kevin@kcrtrans.com
(951) 688-1904
