August 12, 2026, 12:48:24 pm
| | |-+  Factory Twin/dual Carb beetles - were there any??? Any Pic's ;)
Author Topic: Factory Twin/dual Carb beetles - were there any??? Any Pic's ;)  (Read 31215 times)
« on: October 18, 2010, 12:41:56 pm »
Well as the title says guys - Where there any FACTORY twin/dual carb beetle's built Huh maybe somewhere other than europe or the US -  Australia Huh South Africa Huh South America Huh
I have been thinking about this for a while now, and I am sure I remember seeing something in volksworld a few years ago  Undecided
So any info/pic's would be cool  Smiley
« Last Edit: November 22, 2013, 02:52:27 am by monkiboy » Logged
roland
lates are the new splits...
« Reply #1 on: October 18, 2010, 12:59:50 pm »
Well the Mach 1 is a special edition made in Belgium by D'ieteren..
Quote
During autumn 1964 Brussels based Belgian VW importer D'Ieteren planned to uprate 300 1200cc Beetles with Oettinger Okrasa tuned 1300/34 TSV engines. However due to pressure from Volkswagen only 29 were finally supplied. These 50hp engines featured counterweighted crankshafts, Solex 32 PBIC twin carburetors, separate cylinder inlet channels, sodium filled exhaust valves. Clutch was from Transporter.
Black interior dash and wheelChassis featured camber compensator, front stabiliser bar, uprated shock absorbers. Wheels were 6.5x15 of Porsche origin, GoodYear radial tires.
Mach 1 frontAvailable as Ruby Red (L456) or Java Green (L518) with optional white centre stripe and side front quarter sticker badges. Interior Black Leatherette, flat black instrument panel with 160km/h speedometer, tachometer and Koch oil temperature gauge. D'IeterenAlso black two spoke steering wheel from the Type 3 1500.
The original 'Herbie'?
More info & pics here http://www.sebeetles.com/mach1.htm and I'm sure fabs can help too Smiley
« Reply #2 on: October 18, 2010, 13:23:46 pm »
Cool cheers dude - I had heard of these little babies but I was hoping more for a REAL factory built setup  Undecided
Maybe I should open it up a little - how about factory type1/2 set-ups Huh Huh Huh Brasilla's  Huh SP2's  Huh Rare optionial extra  Huh
I am just sure I remember seeing a little history thing in VoWo Mag a few years back with a Bug with a nice dual Solex set-up but I can not find the article anywhere  Undecided
Any ideas guys  Smiley
« Reply #3 on: October 18, 2010, 14:53:19 pm »
are you talking about the der express kit  Huh in vowo
don't remember that vw made some bug with dual carbs ??
i know there's the rally beetle with oettinger it had dual carbs
the car was a special edition made only @3500 cars
ps  : not sure if the engine was offer by vw Huh
« Last Edit: October 18, 2010, 15:45:46 pm by speedwell » Logged
RFbuilt
« Reply #4 on: October 18, 2010, 15:10:26 pm »
another factory beetle would be the ":champagne" edition  which had i think dual 32s (solex)
not sure which countries had this available
« Reply #5 on: October 18, 2010, 15:28:27 pm »
lee check here you will found what you want on the special beetles , all are may be not factory but there's some cool info
« Reply #6 on: October 18, 2010, 15:34:23 pm »
1975 SP 1600south africa
« Reply #7 on: October 18, 2010, 15:36:00 pm »
1975 Nordstadt VW Cabrio - Germany
Featuring a 2.0 liter Oettinger engine, ATS wheels
« Reply #8 on: October 18, 2010, 15:48:11 pm »
1986 Last Series - Brazil
may be a real dual carbs factory car
1303 style rear lights and wings. VW of Brazil offered the 'Fusca Ultima Serie' - Last Series Beetles - with both gasoline or alcohol 1600 engines. However, only the alcohol-powered ones had two carburetors. The 'single-port' cars, gasoline-powered, had an air-cleaner unlike the most recent Mexican models, and developed 53 hp
« Reply #9 on: October 18, 2010, 15:49:22 pm »
another one from brazil
1985 Special Series - Brazil
Engine: 1600cc, twin carburetors, 57 hp, powered by sugar cane alcohol.
« Reply #10 on: October 18, 2010, 15:50:40 pm »
1984 Love Series - Brazil
The engine was a new 1,600cc with twin carburetors, 57 hp and powered by sugar cane alcohol. Maximum speed was about 135 km/h
« Reply #11 on: October 18, 2010, 16:40:25 pm »
1972 VW GT - Austria
The 'Austro Sportkit' 1600 engine comprised modified heads and ports with higher compression, Porsche 914 4 cylinder valve springs and dual carbs - upping the power output to 65hp and a top speed of 145km/hour. 0-80km/h - 10.5s, 0-100 - 16s, 0-120 - 24s.
Joel Mohr
« Reply #12 on: October 18, 2010, 21:06:40 pm »
.....and don't forget Puma's came with Kadrons.....
SEE YA AT THE RACES!!!
« Reply #13 on: October 18, 2010, 21:38:59 pm »
Any pic's  Huh Smiley
Also any more info on the "RALLYE 1303" engine  Huh what are the carbs Huh whats the linkage Huh and how does that oil filter work  Huh
« Reply #14 on: October 18, 2010, 22:02:05 pm »
it was oettinger/okrasa engine , don't know the species , but may be this one is similar to this one
and there also those oettinger /okrasa version
« Reply #15 on: October 18, 2010, 22:07:09 pm »
forgot what i wrote lee , i found the species in my archives  Grin sorry it's in french
« Reply #16 on: October 19, 2010, 12:13:28 pm »
maybe not as spectacular, but type3's had dual carbs from the factory  Roll Eyes and think Ritter (or so) made a special piece to convert this setup on a beetle. type3 manifolds, special extention piece and original type3 carb.
« Reply #17 on: October 19, 2010, 22:15:58 pm »
Cheers for the info Nicolas but I am looking for a REAL factory set-up, there sems to be a couple of options, I like this one best so far  Smiley
Any more info on the oil filter set-up Huh Huh Huh
« Reply #18 on: October 20, 2010, 11:07:51 am »
The oil filter system was abandoned because it didnt do much good after all. It was/is a "bypass" filtering system. It created issues with the flow to the factory cooler. - Berg tried to improove on the set up in the late 90íes. But was soon abandonded again because it didīnt catch up.
WRT factory twin carbed beetles. - Wasnt there an export model for the commonwealth countries ? I seem to remember to have seen one at a show in the UK about 15 years ago. supposidly 1600 cc. with twin 32 mm. Solex PDSIT (type 3) on tall manifolds.
RFbuilt
« Reply #19 on: October 20, 2010, 11:11:08 am »
torben , i think the champagne edition beetle is quite similar..
tall manifolds.. locally in my country (southern east asia) ive seen a few..  but most are rotted or hacked up for parts.. so sad
anomaly
« Reply #20 on: December 06, 2010, 02:53:22 am »
speedwell:
Can you or someone else help me find a source of parts for a 1986 Brazilian alcohol burning bug?
My wife's brother has one and he's having trouble finding parts in Brazil.  I thought I might be able to locate some here in the US or online from a European vendor.
Failing that is it possible to convert a gas carb to alcohol?
Any information would be appreciated.  We are going to visit in two weeks and I'd really like to have a solution for him when I get there.
« Reply #21 on: December 06, 2010, 18:38:53 pm »
sorry i'm from belgium  Roll Eyes but i know a brazilian guy who live in brazil  Grin (no kidding) may be he can help
Per Ericson
« Reply #22 on: December 09, 2010, 14:08:40 pm »
speedwell:
VW Do Brasil didnīt follow the german/mexican evolution. When the alcohol version was introduced 1984 the engines received updated heads and dished pistons. The only differences between a gasoline and an alcohol engine in Brazil are the pistons and the jetting. Both engines uses dual 32 PDSIT. Parts should be available from any vw dealer in brasil. These engines were used in brazilian buses until 2006.
« Reply #23 on: January 02, 2011, 02:50:49 am »
« Reply #24 on: November 22, 2013, 02:51:36 am »
I am bumping this thread to go with my "Bus Motor" thread.....
Any more info as its been a couple of year  Shocked Cheesy Smiley
