October 14, 2026, 06:59:48 am
Cheap and free improvements, or taking time to do the un-fun stuff.
Topic: Cheap and free improvements, or taking time to do the un-fun stuff. (Read 14942 times)
October 20, 2010, 16:11:33 pm »
For the next few years at least, I’m going to focus on fixing and improving my ’67 mainly doing jobs that cost little or no money. After a quick search, I didn’t turn up any threads on the subject, so why not start a discussion? There are lots of clever folks here that probably have very good insight on the subject, and I know there are some members with very nice driving/detailed cars.
So, let’s talk about what you’ve done, or are planning on doing to your car that involves mostly just time and patience.
My plans for the foreseeable future include:
Bodyworking my distorted overrider holes
Cut/tweak fitment of dual muffs
Clean and detail job — jack up car and clean inner fenders, rockers, suspension and brakes
Go through electrical, clean up ground connections, fix horn and dome light
Tidy up interior — detail dash, mount gauges, clean and lube lock and window mechanisms
Dave Rosique
nobodyouno
Re: Cheap and free improvements, or taking time to do the un-fun stuff.
October 20, 2010, 16:27:04 pm »
Good idea Mike..
I'll start with a little trick that may help some:
58-65 T1 Accelerator pedal repair (non roller pedal)
Weld the backside of the washers located on the Z bar that connects the pedal to the cable.
This mod really helps eliminate side play and firm up the pedal.
jick
October 20, 2010, 17:06:50 pm »
Quote from: Dave Rosique on October 20, 2010, 16:27:04 pm
Good idea Mike..
interesting....somebody back in the past has done this to my'59
www.custommotorbodies.co.uk
Dave Rosique
nobodyouno
October 20, 2010, 17:42:33 pm »
Quote from: jick on October 20, 2010, 17:06:50 pm
Good idea Mike..
Maybe I worked on it!
October 20, 2010, 19:49:42 pm »
Great start, Dave!
Threads like this can help motivation. Bring it on!
October 20, 2010, 20:38:03 pm »
I have a list of crap I have done over last year, I'm only going to share the cheap/free ones, and there will be more to come of the cheap, as Bug money is directly inverse to number of kids you have. One increases as the other decreases.
kafercup turned over a nice set of used rear Konis and I finally got 'em on last year and I have to say, aside from a bigger cc motor, these are the best thing a guy can do to his car to make it feel "faster"
I did my own alignment around same time and got rid of KYB GR2's up front. Used the chalkline and jackstands method on the align and went to stock Boge front shocks with stock snubbers (that I shortened)
replaced "Z" shaped threaded rods from Berg linkage to carbs with real L/R thread rods and ball joints.
Had my bud Holleran weld gussets on bottom of my IDA manifolds
next up is fixing wipers so they work like new, mounting '67 reverse light lens/frame in front kick panel carpeting (just ahead of shifter) for extra courtesy light, and sourcing a working rear 1970 or so defrost rear glass and the crap to make it work.
Just got rid of my 145 and went to Smart tires (175/55) though I wouldn't classify that as cheap.
Mike Maize
October 21, 2010, 02:21:09 am »
OK this is right up my alley! Hauer knows I obsess with everything working "right". Here are a couple I do to every car I build because I have found they help with that "new" feeling.
1. Completely disassemble pedal assembly and lube/rebuild .......should cost free to cheap.
2. Disassemble shifting assembly and re-bush carrier in tunnel. Polish rod...always a favorite
New coupler, with factory cage, lube and reassemble. Should cost cheapish..
3. Remove then disassemble, clean, and lube turn signal switch. Take your time and have a beer on this one
Free if you don't break it.
4. Service the bearing (bushing in early cars) in the steering column. Pain in rear...BUT.....cheap. Gives the steering a more buttery feel.
5. Adjust the brake pedal push-rod to the Bently Manual spec. Adjust the brakes.......freeeeee
I understand some of these may be no brainers to some, but I have driven some very "nice" cars without any of it done and they just don't feel "right".
Hey Jim, I thought you were going to try the 185/60/15's?
October 21, 2010, 03:05:47 am »
Quote from: Mike Maize on October 21, 2010, 02:21:09 am
OH yeah...I'm reminded of this one every time I drive. Add to list...
Bryan Nunes
October 21, 2010, 04:47:01 am »
On my 65 I fixed the pedas about two or three times, got pissed and took the whole thing out and put a set of 67 pedals in no more gas pedal problems. But nothing bets replacing the shift rod bushing and shift coupler, than if feels like butter.
youngnstudly
October 21, 2010, 05:51:10 am »
I'll share the one that I have been hiding from for quite a while...Finishing the undercoating under the fender wells
(I've already done the hard part of scraping and undercoating the parcel tray underneath while the trans was out, but I never finished the fender wells). I also have to replace the bumper bracket grommets and most of the "small" rubber seals and grommets on the body so the car doesn't sqeak and chafe everytime I hit a bump. Running board grommets come to mind here too! I'd also like to install the glovebox door rubber stops so the door will open when I hit the button.
Andy
October 22, 2010, 18:02:34 pm »
Hi Mr. Maize...
I looked at the 185/60 and 175/65 but I think they would have scuffed fenders on full lock on the canyon road I drive to work (the old 145's would just buzz under there), and I'm not a beam narrowing guy, unless disc brakes force my hand (CSP's may be in the near future, my guy tells me they only stuff wheels out 6mm per side). Besides aren't the 80's coming back?
I need to do my shift coupler, but man I have avoided it fo so long. Last one I did was 1990 and it was a real joy.
Jim
Last Edit: October 22, 2010, 21:52:55 pm by Atom Heart Mother
Mike Maize
October 23, 2010, 00:08:27 am »
Ha Jim!
Do that shift coupler....you will thank me.....
October 23, 2010, 00:22:01 am »
Quote from: Atom Heart Mother on October 22, 2010, 18:02:34 pm
They will when I get my '67 running!
October 23, 2010, 01:01:18 am »
Quote from: Bryan Nunes on October 21, 2010, 04:47:01 am
On my 65 I fixed the pedals about two or three times, got pissed and took the whole thing out and put a set of 67 pedals in no more gas pedal problems.
Thus proving, once again, that '67 VW technology is your friend.
October 25, 2010, 18:46:27 pm »
Mikes: you two got to me.
R&R'd my shift bushing (what I meant above, not "coupler"). Had a few spare hours Saturday and just got in there and did it. Not much left of the original. Now I remember why I have been putting off this job for 20 years. It does shift much nicer now though.
October 25, 2010, 18:52:01 pm »
Tightening the steering box...
October 25, 2010, 18:57:02 pm »
Just got rid of my 145 and went to Smart tires (175/55) though I wouldn't classify that as cheap. Quote from A.H.M.
I have a pair of those... Doesn't that size leave an awful gap fenderwise ? (They will get me around corners though...)
October 25, 2010, 19:56:38 pm »
Quote from: FDK/Hurry on October 25, 2010, 18:57:02 pm
Hi Harry, no I don't think they leave the fender-opening gaping. They are about 1.5" shorter in overall diameter than the 145 I took off. I did push the car, with some vigor, through my route to and from work last week and I have to say there was a night and day difference in turn-in feel and steering response. I could enter 2nd gear corners with brakes on much later and get off them earlier as well and apply power harder and earlier. Big time improvement. If I was worried about the look of things more than how they worked, I guess they would take some getting used to. I need to reset my camber now for some reason, which means resetting toe too. After I get it dialed in further we'll see how it does. Carlos has been bugging me to go up another CA33 run.
October 25, 2010, 20:27:42 pm »
One pic, thousand words. I'll bet those Smarts will look good on my 6" Cookies.
lawrence
October 26, 2010, 06:46:59 am »
Good call on the tire swap, Jim. Im sure it will give you a new appreciation for the car. I love the 185/65 on my car and will probably never go back to the drag look.
"Happiness is a Hot VW!"
August 10, 2011, 17:02:51 pm »
Bringing this back from the dead! Anybody "improve" their car lately?
So far this season for me:
Clean/lube turn signal switch (altho technically I did break it too)
Pedal cluster is cleaned and lubed with manicured clutch hook, ready to go back in car
Installed factory alternator pulley I had saved
Bent up a scoop to ram air into the external oil cooler under the car
Mike Maize
August 10, 2011, 19:41:06 pm »
Installed an old finned Oberg and "high-tech" staging brake on my 67
August 10, 2011, 20:59:54 pm »
Show everybody the staging brake! Its your best work ever.
JezWest
August 12, 2011, 18:45:05 pm »
Sanding the brass horn ring contact on the steering wheel to stop the annoying scraping noise when steering.
Adjusting the oil cooler tin to get a proper seal.
Installing head temp sender & gauge.
Replacing the head stud I snapped whilst retorqueing the head studs (oops!).
August 14, 2011, 02:02:19 am »
Quote from: JezWest on August 12, 2011, 18:45:05 pm
Take it easy ya brute!
